I'm not entirely sure where to post this, and I thought maybe someone in the community may know the answer or where to get help from, so here goes...
I'm using the Android Things Starter Kit with the PICO-PI-iMX7 board and the included 5" display.
I'm looking to get a larger display but I'm not entirely sure what the compatibility is. The included display uses an FPC connector (I think?), here's a link to it: https://shop.technexion.com/tdp0500t800480pcap.html
The board lists compatibility for two types of displays:
- 24-bit TTL RGB signals
- MIPI DSI on a 33-pin FPC connector
How would I know if the display is compatible? Do all TTL displays come with the same connector size/compatibility? Or is it like the FPC connector which seems to vary in size? Is there any way to use a standard HDMI monitor?
Thank you
https://linustechtips.com/topic/1046075-android-things-help/
