Help with a pc build?
Go to solution Solved by LukeSavenije,
4 minutes ago, GoldenLag said:
CPU: AMD - Ryzen 5 2600 3.4 GHz 6-Core Processor  ($250.00 @ Shopping Express)
Motherboard: ASRock - B450M PRO4 Micro ATX AM4 Motherboard  ($123.00 @ Shopping Express)
Memory: Crucial - Ballistix Sport LT 16 GB (2 x 8 GB) DDR4-3000 Memory  ($146.30 @ Newegg Australia)
Storage: Crucial - MX500 500 GB 2.5" Solid State Drive  ($99.00 @ Austin Computers)
Storage: Toshiba - P300 2 TB 3.5" 7200RPM Internal Hard Drive  ($69.95 @ Mwave Australia)
Video Card: MSI - GeForce RTX 2060 6 GB VENTUS OC Video Card  ($556.60 @ Newegg Australia)
Case: Cougar - MX330-G ATX Mid Tower Case  ($58.00 @ Umart)
Power Supply: Corsair - CX (2017) 550 W 80+ Bronze Certified ATX Power Supply  ($85.00 @ Shopping Express)
Total: $1387.85
Generated by PCPartPicker 2019-03-18 23:51 AEDT+1100
here you go. way below budget
i got a little down
sorry, i felt i had to try
[I APOLOGISE IN ADVANCE FOR THIS BEING WRITEN LIKE CRAP my phones keyboard is tiny]
So I decided that its time for me to not use a macbook air and get a real pc. I made this list with no real research i tried to get under 1.5k aud but failed im just wondering how can i make this cheaper/compatible. (Headset, keyboard, and mouse are not needed)
(I decided it would be smart to post this before i went to sleep so i wont reply for the next few hours)
https://linustechtips.com/topic/1045671-help-with-a-pc-build/
Total: $1387.85
https://linustechtips.com/topic/1045671-help-with-a-pc-build/#findComment-12403270
Total: $1387.85
i got a little down
https://linustechtips.com/topic/1045671-help-with-a-pc-build/#findComment-12403279
I would suggest a few things.
First, upgrade to a WD Black, as it is centered around performance and would suit your build better. Second, your power supply should be 600W, even though your build only requires 300W, because this will allow for overclocking, futureproofing, and more efficient power draw. Thirdly, I suggest using Kinguin for windows, as its $20 for a license key, and saves you plenty.
https://linustechtips.com/topic/1045671-help-with-a-pc-build/#findComment-12403401
8 hours ago, LukeSavenije said:
Thank you soo much, both of you there is a case i kinda like (spec omega rgb) do you think all these parts could fit that?
(If they dont you dont need to chnage the list)
https://linustechtips.com/topic/1045671-help-with-a-pc-build/#findComment-12404863
it would fit
tho you can check with any case on pcpartpicker, it automatically checks for you
tho the motherboard is a bit smaller, which some may or may not like
https://linustechtips.com/topic/1045671-help-with-a-pc-build/#findComment-12404876
14 minutes ago, LukeSavenije said:
no problem
if you need anything, let me know
otherwise you can mark it solved
I think i can mark it as solved right after i know this, how many usb ports on the motherboard and do they aligne with the spec omega rgb, and the  corsair 570x crystal
One agin thanks
https://linustechtips.com/topic/1045671-help-with-a-pc-build/#findComment-12404959
One agin thanks
this is all the back io the motherboard has
it should work with both, tho i think there are better cases for the price than a 570x
https://linustechtips.com/topic/1045671-help-with-a-pc-build/#findComment-12404972
i prefer the looks of the case but if you could think of a better one i would appreciate it but its not needed.
https://linustechtips.com/topic/1045671-help-with-a-pc-build/#findComment-12405148
