Hi Community,
I have a Dell Latitude 3390 2 in 1 that says it supports DP 1.2 through its USB C port, and I have a regular HDMI monitor. Does this mean I will need an adapter from USB C to DP, and then DP to HDMI, or will a USB c to HDMI be just fine?
Any help would be appreciated.
Thanks in advance.
https://linustechtips.com/topic/1045260-usb-c-display/
5 minutes ago, SZ1357 said:
Hi Community,
Thanks in advance.
USB to HDMI is fine, it does the DP -> HDMI conversion in the adapter.
https://linustechtips.com/topic/1045260-usb-c-display/#findComment-12399784
