So I built My first rig today and just wanted to se if the temp for my cpu was normal. It's an fx-8320, not oc, with stock and cooling, and when I enter the Bios, it says 43 Celcius, or sometimes 46 Celcius. Just wanted to know if this was normal, or if I did do something wrong. I did wipe off the stock stock heatsink Thermal Compound with Isopropyl Alcohol, because It dried because I tested it and took it apart and traveled with the parts. I also want to know a program to check my temps while not in the bis. Tried downloading CPU-Z but it downloaded something else every time. Any Links?
Gaming Rig "Project Primitus" - AMD FX-8320 CPU, Asus M5A97 R2.0 Mobo, G.Skill Sniper Series 8GB RAM @1866 MHz, WD Caviar Blue 1TB, Gigabyte Geforce GTX 760 GPU, Fractal Design Define R4 Window, Corsair CX600 PSU
Pics and my reviews for the build here - http://pcpartpicker.com/b/LvN
Peripherals - Corsair Vengeance K70 MX Red, Logitech G402,Kingston HyperX Cloud, 21" TV, Steelseries QcK Heavy Mousepad, Macbook Pro 2012 13"
https://linustechtips.com/topic/104515-normal-cpu-temps-with-stock-cooling/
43 to 46C is normal, my 5800K even idle at 50C
50C idle? WHAT!? Are you sure your heatsink is secured? That is way above normal. No processor should idle more than like 40C. Most of what I have seen idle @ 32-38C.
What brand of thermal paste did you replace it with? How much did you put? Did you spread it out before hand? What is your CPU cooler? That is a HIGH idle temp if not overclocked.
CPU: i7-3930K @ 4.8GHz MOBO: IV Gene RAM: 16GB Crucial Ballistix Tactical Tracer 1866MHz GPU: GTX 780 Ti CASE: Corsair 350D STORAGE: 2 x Samsung 840 Pro 256 GB, 2x WD Red 4TB
PSU
: EVGA SuperNova 650W DISPLAY: 1 x ASUS VG248QE, 3 x Dell U2414H COOLING: Corsair H100i INPUT: Corsair Vengeance K70, SteelSeries Sensei AUDIO: Sennheiser HD 280 Pro, ATH-M50s, Beredynamic DT770 Pro, Steelseries H Wireless
Most of the time it idles at 43, I've only seen 46 once. I installed it correctly, I used the pea method for thermal compound hope I didn't mess up. It is stock cooling btw. I also ran it all of today with a couple restarts and no games and it stayed that way
This is the thermal compound http://www.amazon.com/gp/product/B000OGX5AM/ref=oh_details_o01_s01_i02?ie=UTF8&psc=1
Most of the time it idles at 43, I've only seen 46 once. I installed it correctly, I used the pea method for thermal compound hope I didn't mess up. It is stock cooling btw. I also ran it all of today with a couple restarts and no games and it stayed that way. This is the thermal compound http://www.amazon.com/gp/product/B000OGX5AM/ref=oh_details_o01_s01_i02?ie=UTF8&psc=1
You failed to mention you were running on a stock cooler. That is normal for a stock cooler. Also the thermal paste is fine. Get a Hyper 212 Evo CPU cooler.
PSU
It says so in the topic sorry and thanks. Yah thats first on my list, then A better monitor instead of a TV, but you do what you do on a budget! :) Thanks
