Micro Build(1st) - Finished
Waiting for my 16gb Dominator Platinum w/ light bars and 2nd 840 EVO 120gb to get here tomorrow and we can get this started.
Case - Corsair 350D Windowed
Mobo - Asus Maximus VI Gene
CPU - i7 4770K
Cooler - H100i
GPU - EVGA Geforce GTX 780 Ti (Superclocked)
Memory - 16gb - 1866 Dominator Platinum w/ light bars
PSU - AX860
Storage - [1]840 Evo 120gb SSD(OS) [2]840 Evo 250gb SSD(Games)  [3]WD Scorpio Black 750gb HDD(Misc - delivered later this week)
Optical - Asus External Slim DVD/RW
Fans - AF140 quiet edition x2(Installed) AF120 quiet edition(Installed) SP120 quiet edition x2
OS - Windows 7 Professional
Monitor - Asus VG248QE + G-Snyc
Mouse - DeathAdder 2013
Keyboard - Ducky Shine 3 green led cherry mx brown (will be delivered late this week)
Corsair 350D + AF Quiet Edition | Asus VI Gene ROG | 4770K OC 4.6ghz | H100i + SP Quiet Edition | 16gb DDR3 1866 Dominator Platinum | EVGA GTX 780 Ti OC | Corsair AX860 | 840 Evo SSD x2, WD Scorpio Black | Asus VG248QE + G-Sync | Ducky Shine 3 | DeathAdder 2013
https://linustechtips.com/topic/104429-micro-build1st-finished/
4660k? Typo?
Haven't you heard? It's a secret prototype :P
[AMD Athlon 64 Mobile 4000+ Socket 754 | Gigabyte GA-K8NS Pro nForce3 | OCZ 2GB DDR PC3200 | Sapphire HD 3850 512MB AGP | 850 Evo | Seasonic 430W | Win XP/10]
https://linustechtips.com/topic/104429-micro-build1st-finished/#findComment-1396784
Check for typos in your post OP, still, looks like an awesome build.
Case:NZXT H440   CPU:3570k @ 4.4ghz   Cooler:Prolimatech Megahalems w/ ap121 p/p  GPU:Gigabyte Windforce GTX 770  RAM:Crucial Ballistix Tactical Tracer 16gb 1600mhz  Mobo:Sabertooth Z77     PSU:Cooler Master Silent Pro M 700w   Wheel: Logitech G27 + joystick as handbrake Asus DGX 5.1        Mouse: Corsair M65     Keyboard: CM Storm Trigger Cherry MX black  Headphones: ATH-M50s    Phone: Nexus 5 32GB  Earphones: Sennheiser CX 400ii    SSD: 120gb 840 evo  HDD: WD Enterprise 2TB    AMP&DAC: Schiit Stack.
https://linustechtips.com/topic/104429-micro-build1st-finished/#findComment-1396788
4660k? Typo?
Edited - Fixed
https://linustechtips.com/topic/104429-micro-build1st-finished/#findComment-1396819
Dare I ask the cost?
Hurts to say, build + peripherals - 3232.71
Saved for a couple months
https://linustechtips.com/topic/104429-micro-build1st-finished/#findComment-1396838
This will be an interesting build to see come to light ,Well done !
Case: | TT Core x71 | Mobo: | Gigabyte Aorus Elite DDR4 | Cpu: 13600K | 1.300V | P-Core 5.6GHZ | E-Core 3.9GHZ | Cpu Block: EK Quantum Velocity2 | Ram: Team T-Force Vulcan Z 4x8GB 3200MHz DDR4 | Gpu: Gigabyte GTX G1 970 Bios Hacked 1.275V | Gpu Block: EK | Cooling: Custom Loop | Rads: 4 | PSU: Corsair RM 1000w
https://linustechtips.com/topic/104429-micro-build1st-finished/#findComment-1396898
Sweet specs :).  I love 350D builds.
CASE: FRACTAL DESIGN DEFINE R4  |  MOBO: MSI MPOWER Z77  |  CPU: Intel i5 3570k @ 4.4 GHz  |  CPU COOLER: NOCTUA NH-D15  |  GPU: EVGA GTX 770 SC |
PSU: CORSAIR AX860 W/ RED BRAIDED CABLES | SSD: SAMSUNG 840 EVO 250 GB | HDD: WD BLACK 1 TB | FANS: 3x NOCTUA NF-A14 | MONITOR: HP W2371D
KEYBOARD: CM STORM QFR MX BLUES W/  PBT KEYCAPS  |  MOUSE: LOGITECH G502 | MIC: AUDIO TECHNICA AT2020 | HEADPHONES: SENNHEISER HD 558
https://linustechtips.com/topic/104429-micro-build1st-finished/#findComment-1397873
I just finished putting all the hardware together and cable management when the DHL guy pulls up and hands me my ducky shine 3! On mobile will post pictures later on
https://linustechtips.com/topic/104429-micro-build1st-finished/#findComment-1401773
Sweet! looking forward to it
PC Specs
Intel i5 4670k 4.2ghz @1.20v | Cooler Master 212 Plus | Asus z87-A | Fractal Design Define R4 |Hitachi 1TB 7200rpm HDD | 2x Samsung 840 EVO | Seasonic 520w m12II | Crucial Ballistix Sport 8gb DDR3 1600mhz | PowerColor 7870 GHz edition | Razer Blackwidow Ultimate 2013 | NZXT Hue RGB Controller
https://linustechtips.com/topic/104429-micro-build1st-finished/#findComment-1402243
GOT EVERYTHING FINISHED!  Sorry it took this long to post pictures but I wanted to get everything done first - Install Windows 7/Update Drivers/Overclock.  I got my 4770K to 4.6ghz, and the 780 Ti w/ VG248QE 144hz w/ G-Sync looks amazing.  The Ducky keyboard is a little smaller than I am use to, but it is awesome and I am getting use to it.  Very Very surprised I had no problems with starting it up and getting everything installed/updated.  Also surprised at how quiet it is, although my last pc was a dell xps that sounded like a jet engine however it is very silent even during stress testing. Anyway sorry the pictures are not as awesome as the pc but I am not a good photographer nor do I have a good camera.
After Overclock CPU is running on average temp of 35c on idle and 75c on 100%
https://linustechtips.com/topic/104429-micro-build1st-finished/#findComment-1407483
Question, Is the 350D big? I'm planning to use one as well.
I would not call it big or small, it is definitely the right size for me.
I am glad I went with the mATX just because I am using mainly for gaming and it has everything the ATX has + can expland to SLi and more memory later on.
https://linustechtips.com/topic/104429-micro-build1st-finished/#findComment-1407625
Oh ok. I will definitely use the 350D then.
https://linustechtips.com/topic/104429-micro-build1st-finished/#findComment-1407640
Looks nice, simple, neat. GREAT JOB as a 1st attempt. Now go remove tht corsair link h100i cable after you set it up, its really pissing me off haha.
CPU - Intel Core I7 4930k @ 4.6GHZ Motherboard - Rampage IV Extreme Black Edition RAM - Corsair Vengeance Pro Red 2400 16gb GPU - 2x Gigabyte GTX 780ti Windforce OC Case - Corsair 750D Storage - 2x Samsung 840 pro Raid 0 and 2x Samsung 840 EVO raid 0 for games PSU - Corsair AX860i Display(s) - ASUS Pro Art 24inch (temporary) Cooling - Swiftech H320 and ALL NOCTUA FANS Keyboard - Corsair K95 Mouse - Logitech g700s Sound - Corsair SP2500
https://linustechtips.com/topic/104429-micro-build1st-finished/#findComment-1408013
I really should I don't even use the link.  I will do that and install this HDD that arrived tomorrow.  Thanks for the suggestion, wouldn't have thought of that.
https://linustechtips.com/topic/104429-micro-build1st-finished/#findComment-1409314
