I have the ASUS ROG Crosshair VI Hero along with the Ryzen 1700x.
I am looking to upgrade to 32gb of RAM, but the QVL is so small I figured I'd ask around since it's not like they test every RAM out there.
I'm looking for either a 2x16gb or 4x8gb kits that run at 3200mhz if possible. Since I know Ryzen loves its RAM.
If anyone could just give me some links to RAM that is compatible with my motherboard, it'd be very much appreciated.
Thank you!
https://linustechtips.com/topic/1043793-need-help-finding-good-ram/
I would recommended Corsairs Vengeance ram, as it has the least problems with CPU clearance ive seen
https://www.amazon.com/CORSAIR-VENGEANCE-3200MHz-Desktop-Memory-x/dp/B01HKF3RMK?th=1
The ram should work with any DDR4 motherboard really
i7 6700k, GTX 1080, Crucial MX 300, Maximus VII Hero, WD Blue, 16 GB RAM
