I'm having a problem when playing Arma 3 my CPU and GPU never go above 40% while i'm playing but my FPS is 15-30 FPS iv' logged in ounce and got a solid 30 and it was playable and now i've logged in and getting a solid 15. I've looked around and someone said add "-noSplash -cpuCount=8 -high" to my steam set launch options but that hasn't helped that much.
Specs:
  • CPU
    AMD FX 8350
  • Motherboard
    Asus Crosshair V Formula-Z
  • RAM
    G-Skill 2133 Mhz 8GB
  • GPU
    Asus Direct CU II GTX 770
  • Case
    Fractel Define R4
  • Storage
    120 GB OCZ Agility SSD + 1TB and 2TB Seagete Barakuda's
  • PSU
    Corsair TX750M
Whatever graphics settings i use i get the same FPS.
https://linustechtips.com/topic/104302-low-fps-on-arma-3/
GPU and CPU?
CPU: i7 8700 GPU: Asus ROG Strix GTX 1080 Mobo: Gigabyte Z370 Gaming 5 Ram: 16GB EVGA SuperSC SSD: Samsung 850 EVO 250GB
HDD: Seagate Barracuda 2TB PSU: TX650M Case: NZXT S340 Elite OS: Windows 10 Mouse: Logitech G403 Mouse Mat: HyperX Fury S Pro XL
Keyboard: CM Masterkeys Pro S (reds) Headphones: Sennheiser HD598 Monitor: Asus 24' MG248QR Devices: IPhone 11 Pro Max + 13' Macbook Pro
https://linustechtips.com/topic/104302-low-fps-on-arma-3/#findComment-1394764
average fps on altis benchmark was 30 for me
fx 8320 @ 4.0ghz and R9 290
settings all highest setting (turned blur/dof down to 40% (shouldn't impact fps)) except supersampling is at 150% and view distance/object distance at 3000
what motherboard do you have
https://linustechtips.com/topic/104302-low-fps-on-arma-3/#findComment-1395640
