Hello :)
First off, let me say me and a friend have spent 2 days trying to solve my issue, looking all over the internet for fixes. Unable to find a solution to my problem.
Recently picked up a gtx 1080, and the fps in the majority of the games I play is poor, and gpu usage is stuck between 20-40% usage.
-Tried reinstalling  drivers
-tried setting performance to maximum performance mode on Nvidia control panel
-power setting in windows
-reset CMOS
finaly reinstalled windows
None of the above have had worked and still getting poor frames, not allowing me to utilize my 144hz monitor which is the reason I upgraded.
Cpu usage is fine.
Pc -
i7 7700k @stock
Asus Strix Z270F
16gb corsair vengeance ddr4 2400mhz
Gtx 1080 Gigabyte
EVGA 600w W1, 80+ White
Any help would be great, thank you xx
https://linustechtips.com/topic/1043019-need-help-gtx-1080-issues/
7 minutes ago, itsatomic said:
Hello :)
-reset CMOS
Cpu usage is fine.
Pc -
i7 7700k @stock
Asus Strix Z270F
Gtx 1080 Gigabyte
What power supply do you have?
1 minute ago, itsatomic said:
EVGA 600 W1, 80+ WHITE 600W, Power Supply 100-W1-0600-k3
Copied from Amazon, when doing benchmark tests, the GPU does run at 90+ usage but not when playing games.
Have you used the diagnostic tool? https://www.nvidia.com/object/nvidia-system-tools-6.08-driver.html
That is very strange. There are only a few suggestions that I can think of
try to re-seat the GPU in the slot.
try a different driver version.
see if you can get full GPU usage in a program like FurMark, or Unigine
install afterburner and make sure no strange settings are set.
none of those are in any order, lol sorry.
Yer my friend and i have spent ages, it's weird, also new development, apex is running at 90-95% usage but still, other games are not....
