Hi,
i just installed a new motherboard, and CPU and my keyboard will not work in the AMIBios screen.
Any help would be appreciated, I’ve tried everything I could think of but I’m relatively new and just doing my best to try and work through this.
Attached a a picture of the screen I’m stuck at for reference.
https://linustechtips.com/topic/1042993-need-help-troubleshooting/
What keyboard are you using?
REMEMBER:
IF YOU WANT ME TO RESPOND, YOU GOTTA QUOTE ME
OR
PUT @Fixinit1 IN YOUR RESPONSE!!!!!
Gosh, I hate it when people forget. Anyway, check out my PC below, and there's a PCPartPicker link on my profile, If you wanna see what I'm planning.
SYSTEM SPECS: Finally ditched the Pentium N3540, now I've got the following:
CPU - Ryzen 5 2400G
GPU - 1060 6GB Gigabyte G1 Gaming
RAM - 16GB DDR4 3000mhz Team T-Force Delta RGB
MOTHERBOARD - MSI B350 Tomahawk
PSU - EVGA 450BT
CASE - PHANTEKS  P350X
Update!!
I managed to get the keyboard figured out but now my PC will not connect to the internet, I’ve tried using a hard line Ethernet cable as well as the wireless the board comes with.
Nothing ever goes according to plan ?. Any help would be appreciated
