I've just recently put together a new system and installed Windows 10 with all current updates. The 2 problems are as follows.
1: Windows is acting incredibly sluggish. Even getting to this point in typing it has frozen twice for about 15 seconds each with nothing responding including task manager. It doesn't like to shut down or restart and sometimes will lock up all together. I've done everything I could to fix this. I've done a sfc scan and repair, DISM RestoreHealth, disk cleanup and have even gone as far as reinstalling Windows a second time. Currently it's not even keeping up as I type.
2: Geforce Experience will not open at all. No matter how I try to launch it. It sometimes opens and give me the error code 0x0003. I have followed multiple links on how to fix this also with no results. And it just locked up for about 10 seconds again.
The Windows problem happened before installing Geforce.
I will post anything that is needed for any assistance.
Please help.
DxDiag.txt
https://linustechtips.com/topic/1042364-help-with-2-problems/
Diagnostics
Windows Error Reporting:
+++ WER0 +++:
Fault bucket 1715249617183810207, type 5
Event Name: MoAppHangXProc
Response: Not available
Cab Id: 0
Problem signature:
P1: Microsoft.MicrosoftEdge_44.17763.1.0_neutral__8wekyb3d8bbwe
P2: praid:MicrosoftEdge
P3: 11.0.17763.348
P4: 5c73b4df
P5: ce41
P6: 192
P7: Microsoft.MicrosoftEdge_44.17763.1.0_neutral__8wekyb3d8bbwe
P8: praid:runtimebroker07f4358a809ac99a64a67c1
P9: 10.0.17763.1
P10:
+++ WER1 +++:
Fault bucket 1585056781952626178, type 5
Event Name: StoreAgentInstallFailure1
Cab Id: 0
Problem signature:
P1: Acquisition;RuntimeBroker
P2: 80246007
P3: 17763
P4: 348
P5: Windows.Desktop
P6: B
P7:
P8:
P9:
P10:
+++ WER2 +++:
Fault bucket , type 0
Cab Id: 0
Problem signature:
P2: 80246007
P3: 17763
P4: 348
P5: Windows.Desktop
P6: B
P7:
P8:
P9:
P10:
+++ WER3 +++:
Fault bucket 1252192475963284026, type 5
Event Name: WinSetupDiag02
Cab Id: 0
Problem signature:
P1: 5
P2: 4
P3: 9
P4: 0
P5: 0x0
P6: 0x0
P7: 10240
P8: th1_st1
P9: 17763
P10: rs5_release
+++ WER4 +++:
Fault bucket 1249469530313903687, type 5
Event Name: WindowsWcpOtherFailure3
Cab Id: 0
Problem signature:
P1: 10.0.17763.1:1
P2: wcp\sil\ntsystem.cpp
P3: Windows::Rtl::SystemImplementation::DirectRegistryProvider::SysOpenKey
P4: 5348
P5: c0000034
P6: 0x27db5671
P7:
P8:
P9:
P10:
+++ WER5 +++:
Cab Id: 0
Problem signature:
P1: 5
P2: 4
P3: 9
P4: 0
P5: 0x0
P6: 0x0
P7: 10240
P8: th1_st1
P9: 17763
P10: rs5_release
+++ WER6 +++:
Cab Id: 0
Problem signature:
P1: 10.0.17763.1:1
P4: 5348
P5: c0000034
P6: 0x27db5671
P7:
P8:
P9:
P10:
+++ WER7 +++:
Cab Id: 0
Problem signature:
P1: 10.0.17763.1:1
P4: 5348
P5: c0000034
P6: 0x27db5671
P7:
P8:
P9:
P10:
+++ WER8 +++:
No Data
+++ WER9 +++:
No Data
This is all showing that windows is failing at updates. So I don't think you are current on updates, it is just failing to install new ones?
Check the harddrive, Right click on it, Properties > Tools > Error Checking
If there are no errors I'd say just try re-installing windows, and don't install anything else this time until windows is actually updated. you can check your motherboards website for updated drivers as well.
https://linustechtips.com/topic/1042364-help-with-2-problems/#findComment-12374949
2 minutes ago, Labeled said:
  Reveal hidden contents
Diagnostics
+++ WER0 +++:
Cab Id: 0
Problem signature:
P3: 11.0.17763.348
P4: 5c73b4df
P5: ce41
P6: 192
P9: 10.0.17763.1
P10:
+++ WER1 +++:
Cab Id: 0
Problem signature:
P2: 80246007
P3: 17763
P4: 348
P5: Windows.Desktop
P6: B
P7:
P8:
P9:
P10:
+++ WER2 +++:
Cab Id: 0
Problem signature:
P2: 80246007
P3: 17763
P4: 348
P5: Windows.Desktop
P6: B
P7:
P8:
P9:
P10:
+++ WER3 +++:
Cab Id: 0
Problem signature:
P1: 5
P2: 4
P3: 9
P4: 0
P5: 0x0
P6: 0x0
P7: 10240
P8: th1_st1
P9: 17763
P10: rs5_release
+++ WER4 +++:
Cab Id: 0
Problem signature:
P1: 10.0.17763.1:1
P4: 5348
P5: c0000034
P6: 0x27db5671
P7:
P8:
P9:
P10:
+++ WER5 +++:
Cab Id: 0
Problem signature:
P1: 5
P2: 4
P3: 9
P4: 0
P5: 0x0
P6: 0x0
P7: 10240
P8: th1_st1
P9: 17763
P10: rs5_release
+++ WER6 +++:
Cab Id: 0
Problem signature:
P1: 10.0.17763.1:1
P4: 5348
P5: c0000034
P6: 0x27db5671
P7:
P8:
P9:
P10:
+++ WER7 +++:
Cab Id: 0
Problem signature:
P1: 10.0.17763.1:1
P4: 5348
P5: c0000034
P6: 0x27db5671
P7:
P8:
P9:
P10:
+++ WER8 +++:
No Data
+++ WER9 +++:
No Data
Thank you for the reply.
On the second attempt of installing Windows 10 I did just that. Nothing was installed until all updates were done. Windows update says I'm current on all updates. But I will check for errors of the harddrive as you said.
https://linustechtips.com/topic/1042364-help-with-2-problems/#findComment-12374957
1 minute ago, Madster said:
My guess is the hard drive is having some issues, try swapping it out and installing windows on a new hard drive.
Thank you for your reply.
The first install was on a brand new Crucial MX500 m.2 drive.
The second attempt was on a used Samsung 850 Evo.
I do have one more ssd I could try it on.
https://linustechtips.com/topic/1042364-help-with-2-problems/#findComment-12374958
What version of windows are you on?
Try also switching what SATA port you are connecting into just to eliminate silly stuff. I don't think it'll change anything but worth a shot.
https://linustechtips.com/topic/1042364-help-with-2-problems/#findComment-12374962
I'm currently on Windows 10 Pro 64-bit.
I included a dxdiag text file in the OP that has the exact details of which build and release it is. Hoping that would give more insight possibly?
https://linustechtips.com/topic/1042364-help-with-2-problems/#findComment-12374965
Diagnostics
+++ WER0 +++:
Cab Id: 0
Problem signature:
P3: 11.0.17763.348
P4: 5c73b4df
P5: ce41
P6: 192
P9: 10.0.17763.1
P10:
+++ WER1 +++:
Cab Id: 0
Problem signature:
P2: 80246007
P3: 17763
P4: 348
P5: Windows.Desktop
P6: B
P7:
P8:
P9:
P10:
+++ WER2 +++:
Cab Id: 0
Problem signature:
P2: 80246007
P3: 17763
P4: 348
P5: Windows.Desktop
P6: B
P7:
P8:
P9:
P10:
+++ WER3 +++:
Cab Id: 0
Problem signature:
P1: 5
P2: 4
P3: 9
P4: 0
P5: 0x0
P6: 0x0
P7: 10240
P8: th1_st1
P9: 17763
P10: rs5_release
+++ WER4 +++:
Cab Id: 0
Problem signature:
P1: 10.0.17763.1:1
P4: 5348
P5: c0000034
P6: 0x27db5671
P7:
P8:
P9:
P10:
+++ WER5 +++:
Cab Id: 0
Problem signature:
P1: 5
P2: 4
P3: 9
P4: 0
P5: 0x0
P6: 0x0
P7: 10240
P8: th1_st1
P9: 17763
P10: rs5_release
+++ WER6 +++:
Cab Id: 0
Problem signature:
P1: 10.0.17763.1:1
P4: 5348
P5: c0000034
P6: 0x27db5671
P7:
P8:
P9:
P10:
+++ WER7 +++:
Cab Id: 0
Problem signature:
P1: 10.0.17763.1:1
P4: 5348
P5: c0000034
P6: 0x27db5671
P7:
P8:
P9:
P10:
+++ WER8 +++:
No Data
+++ WER9 +++:
No Data
SSD has been scanned. No issues were found.
https://linustechtips.com/topic/1042364-help-with-2-problems/#findComment-12374967
