I've been using the internal recording capability of the Lumix G7 recently and have not been especially pleased with the results. I am considering using my existing capture card to record at a higher bitrate than the internal 100 mbps limit. What I am not sure of is if I should attempt to record at an incredibly high bitrate inside their media express software (prores perhaps) or use OBS instead and increase the bitrate drastically (still h.264). It is also not clear if the Lumix G7 pushes 10 bit or 8 bit video through the HDMI output, so I would want to adjust prores settings accordingly to not waste bandwidth in the latter case. Has anyone attempted to do this?
PC Specs:
CPU: AMD 1700x Cooler: Corsair H100i V2 Motherboard: Asus Crosshair VI Hero RAM: 4 * 8GB G.Skill RGB DDR4 Graphics: EVGA GTX 1080 Ti SC2 Storage: Samsung 960 EVO 500GB Case: Fractal Design Meshify C PSU: EVGA 750w G3 Monitors: Dell SG2716DG +  2x Dell U2515H
Freenas specs:
CPU: Intel Xeon E5-2650 V2 Cooler: Some noctua cooler Motherboard: Supermicro X9 SRL-F RAM: 8 * 8GB Samsung DDR3 ECC Storage: 6 * 4TB Seagate 7200 RPM RAIDZ2 Controller: LSI H220 Case: Phanteks Enthoo Pro PSU: EVGA 650w G3
Phone: iPhone 6S 32 GB Space Grey
https://linustechtips.com/topic/1041813-intensity-pro-4k-and-lumix-g7/
