i need help with my grpahics card comatibility optiplex 9020 pci
Solved by sniperking25,
3 minutes ago, Belezeebub said:PCIe x8 is enough for a video card pcie x4 is not you could put a single card in the blue slot if it will fit in the case.
The black slot is physically a PCIE x16 but it is only wired for pcie X4 so you could not add a second card or use the black slot for your main video card
Hope that makes it as clear as Mud.
Thanks
Featured Topics
ave11 ·
Posted in Troubleshooting2 -
10
idk_what.iam.doing ·
Posted in New Builds and Planning4 -
8
RevGAM ·
Posted in Member Reviews0 -
12
1
6
1
play_circle_filled
Latest From GameLinked:
Are you excited for Doom: The Dark Ages? - Gamers 2 Gamers
