9700k max temps?
Go to solution Solved by Mister Woof,
2 minutes ago, HoneyBadger84 said:
Stress test for aida64 is merely a good starting point. Do not trust it as an overall stress test.
What I mean by that is: if it fails an hour of AIDA64 something is clearly unstable, but if it passes, that doesn't mean you're totally stable.
For reference, I've had settings pass an hour of combined CPU FPU Memory stress testing on AIDA64 and fail elsewhere. I've also had a RAM OC pass an hour of Memtest only to fail AIDA64's in 10 minutes. So a good mix of tests, along with just plain gaming on it and seeing if it freezes is highly recommended when testing an overclock for stability. I personally still use Prime95 26.6 as well even though some people swear against it these days as you see "unrealistic Temps" in it.
My personal gamut is Cinebench once, if it fails, back to BIOS. If it passes
-> 2 hours of A64 stressing CPU/Memory/FPU/GPU
-> 2 hours of Realbench
-> run your normal shit
if it passes all that stuff, it's probably fine.
anything under tjmax is fine; 78 is fine, 63 is fine.
for comfort, at full load anything under 90 is great
i5-14600KF // 120x38MM Cooler Master AIO // B760i // 64GB DDR5 6000 // PNY RTX 5070 // Cooler Master NCORE 100 Max // Cooler Master V SFX-850 Gold // UWQHD AOC Display
https://linustechtips.com/topic/1040484-9700k-max-temps/#findComment-12357959
2 minutes ago, Collinator24 said:
Under load in aida64 it goes up to 63.
Use FPU in AIDA64 instead
Desktop benching:
https://linustechtips.com/topic/1040484-9700k-max-temps/#findComment-12357960
73C is nothing. These chips can go up to 100C before they thermally throttle. As long as you're under 90C load you're good to go. The lower the better, of course.
My load Temps are high 70s under load on mine at 5GHz 1.29V, so you're fine.
Primary Rig:
CPU: AMD 7800X3D @ Stock PBO - Mobo: Gigabyte X670E AORUS Master
2 x 48GB G.Skill Trident Z Royal 6400MHz CL32 1.35V @ 6200MHz CL28-37-32-30 1.5V (still tuning)
CPU Cooler: EK AIO that will be being replaced when I get the chance - PSU: eVGA P2 1200W
GPU: Gigabyte RTX 4090 Gaming OC @ either 2595MHz @ 900mV or 2970MHz @ 1070mV
Case: Thermaltake View 91 - SSDs/HDDs: 1 Samsung 980 Pro 2TB, 2 990 Pro 2TB M.2s, 1 990 Pro 4TB M.2, 1 TeamGroup Cardea Z440 2TB M.2, 1 Seagate EXO X10 10TB HDD
Monitor: Samsung Odyssey G9 49" Super-Ultrawide 240Hz Monitor
https://linustechtips.com/topic/1040484-9700k-max-temps/#findComment-12357997
Thanks for the info. I have been running a stress test on the FPU and CPU for 22 mins now, everything seems stable.
https://linustechtips.com/topic/1040484-9700k-max-temps/#findComment-12358001
Primary Rig:
https://linustechtips.com/topic/1040484-9700k-max-temps/#findComment-12358008
https://linustechtips.com/topic/1040484-9700k-max-temps/#findComment-12358015
7 hours ago, Collinator24 said:
Hello,
I recently overclocked my 9700k to 5ghz, and under load running userbenchmark my temps go up to 78 degrees Celsius. Under load in aida64 it goes up to 63. Is that okay? I have a freezer 33 esports one cooler that keeps it at like 40 idle.
Got a 9700k, climbs to 85C when playing BFV 4k high specs RTX on DLSS off.
No worries :)
Just another engineer posting useful hardware videos directly to the interconnected network (AKA the internet)
Tech enthusiast. Check my channel out here https://www.youtube.com/channel/UC6FU1nfeGBBnw_bvHgWCqTQ
https://linustechtips.com/topic/1040484-9700k-max-temps/#findComment-12358811
