Clip Studio Problem
Go to solution Solved by A_person,
It was a Nvidia Driver Issue.
I'm having a problem with Clip Studio. The fps of my games will drop about 30-50fps whenever i install it.(Basically unplayable)
I uninstalled it but it didn't fix the problem so i reset my pc and hey presto it's fixed.(Reset as in uninstall everything)
I wanted to know what Clip Studio is doing to drop my fps even after uninstalling?
Thanks for the help.
Gpu: GTX 970
Cpu: i5-4690k 4.2GHz
https://linustechtips.com/topic/1040318-clip-studio-problem/
