Hi,
Based on below specs, please suggest which VA/watt UPS is suitable for me.
I do not face long power cuts, only need my system to remain up for few minutes, without overload.
Processor Intel 2600K
GPU 1080 Ti DUKE
HDD
Maxtor 6B160MO (12.2 Watts max)
Seagate St2000dm001 (8.0 Watts max)
WD5000aakx (3.3 Watts max)
Monitor
23 inch LED
Memory
2 x 8GB DDR3
2 x 4GB DDR3
Motherboard
Intel DZ68PL ATX
PSU Seasonic 620W
Case Phantom 410
- Thank you
https://linustechtips.com/topic/1039080-which-ups-will-be-suitable/
You have a 620W PSU and a 35-50W monitor. Some people would recommend a 670+W UPS.
I am considering the actual power draw of your components + some spare room so I'd say a 550-600W UPS would do fine.
1000-1200 VA should equal to 550-650W.
M.S.C.E. (M.Sc. Computer Engineering), IT specialist in a hospital, 32+ years of gaming, 20+ years of computer enthusiasm, Geek, Trekkie, anime fan
  • Peripherals: LG 32GK650F - Dell P2319h - Logitech G Pro X Superlight with Tiger Ice - Madlions MAD 68HE Pro - EndGame Gear MPC890 - Genius HF 1250B - Akliam PD4 - Sennheiser HD 560s - Tripowin Vivace - Simgot EM6L - Truthear Zero - QKZ x HBB - 7Hz Salnotes Zero - Logitech C270 - Behringer PS400 - BM700  - Colormunki Smile - Speedlink Torid - Jysk Stenderup - LG 24x External DVD writer - Konig smart card reader
  • Networking: Asus TUF Gaming AX6000 - Huawei OptiXstar EG8145X6-10 - 1000/500 Mbps fiber optic Internet access
  • TV and gadgets: TCL 50EP680 50" 4K LED + Sharp HT-SB100 75W RMS soundbar - Samsung Galaxy Tab A8 10.1" - OnePlus 13 16GB/512GB - OnePlus 9 256GB - Olymous Cameda C-160 - GameBoy Color - Miyoo A30 Spruce
  • Livingroom PC (dad uses): AMD FX 8300 - Arctic Freezer 64 - Asus M5A97 R2.0 Evo - 2x4 GB DDR3 1833 Kingston - MSI Radeon HD 7770 1GB OC - 120GB Adata SSD - 500W Fractal Design Essence - DVD-RW - Samsung SM 2253BW - Logitech G710+ - wireless vertical mouse - MS 2.0 speakers
Just because the pSU is rated for that doesn’t mean the draw will that. Most pc on  idle around 50w and with everything under load for this spec 300-400w.
@Rahul Saini
 Your in the $100  Territory
There is no enemy. The foe on the battlefield is merely the manifestation of that which we must overcome. The doubt, and fear, and despair. Every battle is fought within. Conquer the battlefield that lies inside you, and the enemy disappears like the illusion it is.
@Rahul Saini
Don't just look at the average under load, when purchasing a UPS you need to consider the peak power draw values, and not the power draw of the components but the power draw the PSU draws from the wall/socket and also most people plug their monitor, speakers, and whatnot to the UPS too.
