Hi everyone,
I'm trying to install CentOs 7 into an old server SunFire X4100 but the hard drives can't be detected in the installation of the CentOs7. The official drivers are no more available for free so, I'm looking any third party driver that makes the magic happens.
Server      : SunFire X4100
Firmware : 1.0v
Storage   :  2x Brand     : Fujitsu
                       Model     : MAY2073RCSUN73G
                       Interface :  SAS
                       Capacity : 73GB
SO          :  CentOs 7.6 x64
Kernel    4.20.10
https://linustechtips.com/topic/1038782-sunfire-x4100-help/
5 minutes ago, KarathKasun said:
You may need to add a sun disk label to the disks through the firmware or disable hardware RAID.
Thanks for the quick answer, the first option is not possible beacause to do that i need to update my firmware and my company its not willing to pay the price off java support. And i dont find the firmware update files anywhere.
The second option its possible but we need set up a RAID config with those drives for ensurance data safety.
https://linustechtips.com/topic/1038782-sunfire-x4100-help/#findComment-12343580
You absolutely can do the first thing, you need to do it through the firmware CLI.  I am not 100% sure if it needs to be done on servers of this vintage though, I remember having to do this in the SPARC-Station era though.
You can do redundancy in Linux with software RAID, BTRFS, or ZFS.
https://linustechtips.com/topic/1038782-sunfire-x4100-help/#findComment-12343588
Hi, thank you very much for your advice. I was able to break the RAID of the disks through the CLI and with that I was able to visualize the disks in the installation. But now I have problems with the network, because at the time of the installation of CentOs7 it does not detect any network device and I already tried it with a TL-WN721N tp-link adapter that works well with CentOs7 but does not detect it either. Any suggestions on how to add a network driver that works for me?
https://linustechtips.com/topic/1038782-sunfire-x4100-help/#findComment-12350576
