Power supply pcie
Solved by Jurrunio,
29 minutes ago, ALI.Mogh said:According to cooler master power supply Calc.
they overblow the numbers anyway
29 minutes ago, ALI.Mogh said:My question is do I need to buy another Psu with higher power or just get an adapter?
New PSU that's not crap, that is. It might as well be lower wattage if your build draws less. What does it have?
tier C or higher is good, below tier D is not
