Wireless or wired 7.1 headset HELP
Hi ok so I need a head set and im in the market for 7.1 headset. I also need a good mic as well that is built in to headset as I plan on doing some video tutorial but I need a good mic with headset.
What is this head set going to be used for movies,games and tv shows and me be music.
I read that it better to have a wired solution but for my set up I think I would need an extension wire just to use it so I might go with Wireless?
As for my correct set up well im a wireless person all my gear wireless as I have my pc hooked up to 50inch plasma tv so I thought of a wireless headset would be amazing but I have read a bit mixed review out there so I have come here in search for help.
Hi might try this Sennheiser PC 363D
http://www.trustedreviews.com/sennhe...dphones_review
or
Razer Tiamat 7.1 – Analog 7.1 Surround Sound Gaming Headset
what do you think?
https://linustechtips.com/topic/103812-wireless-or-wired-71-headset-help/
