Hey guys, so I was wondering that when you go and enable nvidia g-sync theres 2 options; Full screen and windowed and full screen. I've heard problems with windowed and full screen so I just wanted some clarification on this thanks. Also, does ti mean border less windowed or just windowed?
https://linustechtips.com/topic/1037643-g-sync-help/
Just now, narrdarr said:
Boarderless window is windowed.
Personally I use both as I tab in and out games a lot. Depending on the game tabbing works better in in boarderless. But I dont have any problems unless I have mutliple gpu intensive apps open as windowed
Ok because I head somewhere about the fall creators update that messed up the windowed function of g sync. Also this monitor AOC G2590FX will it work exactly like g sync even though its free sync? Its on the list of g sync compatible monitors from nvidia. Will there be any differences between running g sync on a free sync monitor and g sync on a g sync monitor?
https://linustechtips.com/topic/1037643-g-sync-help/#findComment-12334294
I dont have experience using free sync monitors with g sync, but from my understanding if it is on the compatibility list it should work the same. With the exception of setup maybe be different. Like have to turn on freesync on the monitor first
https://linustechtips.com/topic/1037643-g-sync-help/#findComment-12334306
Ah, a;right thanks.
https://linustechtips.com/topic/1037643-g-sync-help/#findComment-12334339
