do you own this pc?
if so you can just measure it
its the length from one  side to the other in millimeters
PC: Alienware 15 R3  Cpu: 7700hq  GPu : 1070 OC   Display: 1080p IPS Gsync panel 60hz  Storage: 970 evo 250 gb / 970 evo plus 500gb
Audio: Sennheiser HD 6xx  DAC: Schiit Modi 3E Amp: Schiit Magni Heresy
https://linustechtips.com/topic/1037380-fan-size-help/#findComment-12332165
From pics CPU cooler looks like normal OEM down-draft. Those have 80mm fans. The rear one is either 92mm or 80mm. Case is 165mm wide and IO plate takes 45mm of it.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/1037380-fan-size-help/#findComment-12332597
