GPU/PSU Help
Go to solution Solved by ibuildpcswsocks,
3 minutes ago, Wolly9102 said:
Does this help? (sry for the low quality max 20 mb upload)
Ohhhh okay, thank you very much!
I am going to be getting a new GPU soon (GTX 1070 8GB) but there is a slight problem. My PSU (Cooler Master 500W) only has 2 6pins, one currently is using my GTX 960.
The 1070 is an 8-pin which I don't have, but I have looked around online such as amazon and this one here seems like it will work.
Any information on what is best to do is greatly appreciated :)
https://linustechtips.com/topic/1037228-gpupsu-help/
What exact PSU do you have?
Main PC:
CPU: AMD Ryzen 7 5700X3D | RAM:Corsair LPX 3200 mhz (32GB)
Mobo:ASUS Strix B550-F Wifi | GPU: Gigabyte 9070
Case: Sharkoon Nightshark RGB| Storage: 500 GB 970 EVO Plus 1 TB WD blue 500 GB Samsung HDD
Monitor: iiyama G-Master G2470HSU-B1 165Hz
Powersupply: Cooler Master GX III Gold 750
Main Laptop
CPU: AMD Ryzen 7 4800H | RAM: Team group 16 GB 2666 mhz
GPU: RTX 2060 (MXM swappable)
Monitor: 1080p 120Hz
Storage: 2x 1 TB Samsung 970 EVO NVMe (no raid)
Second Laptop
CPU: Intel Core I5 1235u,  RAM: Crucial 16 GB 3200 mhz
GPU: IrisXe 80 eu
Storage: 512 GB WD Digital SN530 NVMe
Phone:
Xiaomi MI 11
Work Phone:
Samsung Xcover 6pro
https://linustechtips.com/topic/1037228-gpupsu-help/#findComment-12330882
I believe I have a Non Modular Cooler Master 500W 80 Plus (I ordered my PC from Ironside because I needed a new computer overall)
sidenote: would this work too? I'm not really trying to spend $30 for a cable ?
https://linustechtips.com/topic/1037228-gpupsu-help/#findComment-12330911
I mean the model name ;) or do you not know? Most PSU's nowdays have 6+2 PCI-E cables
Main PC:
Main Laptop
Second Laptop
GPU: IrisXe 80 eu
Phone:
Xiaomi MI 11
Work Phone:
Samsung Xcover 6pro
https://linustechtips.com/topic/1037228-gpupsu-help/#findComment-12330920
The model name I dont know, but yes it does have 2PCI-E Cables, but they have a little "tetris block" on the side of it and I don't know what that is used for because I tried putting it into my GPU which is the 6pin and it wouldn't go in.
https://linustechtips.com/topic/1037228-gpupsu-help/#findComment-12330947
you mean like this?
Main PC:
Main Laptop
Second Laptop
GPU: IrisXe 80 eu
Phone:
Xiaomi MI 11
Work Phone:
Samsung Xcover 6pro
https://linustechtips.com/topic/1037228-gpupsu-help/#findComment-12330978
2 minutes ago, MrFluffyOwnsU said:
Yes!!
You can put the little 2 pin over the 6 pin to make an effective 8 pin :)
Main PC:
Main Laptop
Second Laptop
GPU: IrisXe 80 eu
Phone:
Xiaomi MI 11
Work Phone:
Samsung Xcover 6pro
https://linustechtips.com/topic/1037228-gpupsu-help/#findComment-12331000
Just now, MrFluffyOwnsU said:
but doesn't the two pin make it where you plug it in? because I tried using it and it wouldn't work cause of the little "tetris block"
Main PC:
Main Laptop
Second Laptop
GPU: IrisXe 80 eu
Phone:
Xiaomi MI 11
Work Phone:
Samsung Xcover 6pro
https://linustechtips.com/topic/1037228-gpupsu-help/#findComment-12331031
Happy to help ^^
Main PC:
Main Laptop
Second Laptop
GPU: IrisXe 80 eu
Phone:
Xiaomi MI 11
Work Phone:
Samsung Xcover 6pro
https://linustechtips.com/topic/1037228-gpupsu-help/#findComment-12331072
