I have recently built my first PC and I am having issues with my pre-installed Aer F fans, When PWM is selected in BIOS, the fans will spin up to their max RPM and cannot be changed, despite the fact that NZXT says they support PWM and the connectors are 4-pin. DC does work for changing RPM.
PC in question: https://pcpartpicker.com/list/KDQPD2
https://linustechtips.com/topic/1037203-pwm-not-working/
Can you repost the list? Can't see it
Main PC:
CPU: AMD Ryzen 7 5700X3D | RAM:Corsair LPX 3200 mhz (32GB)
Mobo:ASUS Strix B550-F Wifi | GPU: Gigabyte 9070
Case: Sharkoon Nightshark RGB| Storage: 500 GB 970 EVO Plus 1 TB WD blue 500 GB Samsung HDD
Monitor: iiyama G-Master G2470HSU-B1 165Hz
Powersupply: Cooler Master GX III Gold 750
Main Laptop
CPU: AMD Ryzen 7 4800H | RAM: Team group 16 GB 2666 mhz
GPU: RTX 2060 (MXM swappable)
Monitor: 1080p 120Hz
Storage: 2x 1 TB Samsung 970 EVO NVMe (no raid)
Second Laptop
CPU: Intel Core I5 1235u,  RAM: Crucial 16 GB 3200 mhz
GPU: IrisXe 80 eu
Storage: 512 GB WD Digital SN530 NVMe
Phone:
Xiaomi MI 11
Work Phone:
Samsung Xcover 6pro
https://linustechtips.com/topic/1037203-pwm-not-working/#findComment-12330690
[PCPartPicker part list](https://pcpartpicker.com/list/KDQPD2) / [Price breakdown by merchant](https://pcpartpicker.com/list/KDQPD2/by_merchant/)
Type|Item|Price
**CPU** | [AMD - Ryzen 5 2600 3.4 GHz 6-Core Processor](https://pcpartpicker.com/product/jLF48d/amd-ryzen-5-2600-34ghz-6-core-processor-yd2600bbafbox) | $164.99 @ Amazon
**Motherboard** | [MSI - B450 TOMAHAWK ATX AM4 Motherboard](https://pcpartpicker.com/product/Hy97YJ/msi-b450-tomahawk-atx-am4-motherboard-b450-tomahawk) | $114.99 @ B&H
**Memory** | [Corsair - Vengeance LPX 16 GB (2 x 8 GB) DDR4-3000 Memory](https://pcpartpicker.com/product/MYH48d/corsair-memory-cmk16gx4m2b3000c15) | $104.99 @ Amazon
**Storage** | [Kingston - A400 240 GB 2.5" Solid State Drive](https://pcpartpicker.com/product/btDzK8/kingston-a400-240gb-25-solid-state-drive-sa400s37240g) | $29.99 @ Amazon
**Video Card** | [MSI - Radeon RX 570 8 GB ARMOR OC Video Card](https://pcpartpicker.com/product/3JdFf7/msi-radeon-rx-570-8gb-armor-oc-video-card-rx-570-armor-8g-oc) | $179.99 @ Newegg
**Case** | [NZXT - H500 (Black) ATX Mid Tower Case](https://pcpartpicker.com/product/p8x2FT/nzxt-h500-black-atx-mid-tower-case-ca-h500b-b1) | $69.99 @ Amazon
**Power Supply** | [Corsair - CXM 550 W 80+ Bronze Certified Semi-Modular ATX Power Supply](https://pcpartpicker.com/product/3hkwrH/corsair-power-supply-cp9020102na) | $59.99 @ Amazon
 | *Prices include shipping, taxes, rebates, and discounts* |
 | **Total** | **$724.93**
 | Generated by [PCPartPicker](https://pcpartpicker.com) 2019-02-23 18:16 EST-0500 |
https://linustechtips.com/topic/1037203-pwm-not-working/#findComment-12330998
Hmm thats indeed odd; those fans are listed as pwm ones alright.
I recently happen to have read this: https://forum-en.msi.com/index.php?topic=291919.0
Different model tomahawk and slightly different issue but is indicative of some msi bios code being flaky with pwm fans.
So best bet at this time would be to check if there is a bios update available.
https://linustechtips.com/topic/1037203-pwm-not-working/#findComment-12332132
