Hello. I recently upgraded my computer to a Intel i7-4790K, Asus Maximus VII Formula. I'm using my old heatsink from my last build "Cooler Master Hyper 212 Evo". I have not overclocked it at all and I'm running 40C at idle on the cpu. Is this ok? And what would a max "safe" temp be underload?
https://linustechtips.com/topic/1036330-cpu-temps/
20 minutes ago, immaguy1234 said:
Yes, 40 degrees at idle is perfectly normal.
This is relative.....
It depends on the ambiance temperature.
And 40c is just a little bit high for me.
A good idle temperature is around 30~35, as for full load not above ~75c
CPU:i7 9700k 5047.5Mhz All Cores Mobo: MSI MPG Z390 Gaming Edge AC, RAM:Corsair Vengeance LPX 16GB 3200MHz DDR4 OC 3467Mhz GPU:MSI RTX 2070 ARMOR 8GB OC Storage:Samsung SSD 970 EVO NVMe M.2 250GB, 2x SSD ADATA PRO SP900 256GB, HDD WD CB 2TB, HDD GREEN 2TB PSU: Seasonic focus plus 750w Gold Display(s): 1st: LG 27UK650-W, 4K, IPS, HDR10, 10bit(8bit + A-FRC). 2nd: Samsung 24" LED Monitor (SE390), Cooling:Fazn CPU Cooler Aero 120T Push/pull Corsair ML PRO Fans Keyboard: Corsair K95 Platinum RGB mx Rapidfire Mouse:Razer Naga Chroma  Headset: Razer Kraken 7.1 Chroma Sound: Logitech X-540 5.1 Surround Sound Speaker Case: Modded Case Inverted, 5 intake 120mm, one exhaust 120mm.
https://linustechtips.com/topic/1036330-cpu-temps/#findComment-12322976
