Is this a bad quality thermal paste?
Compared to the ridiculously affordable thermal paste from eBay, no difference with Pentium 4 or i5-3570.
But with laptops, compared to factory applied compound, temperatures drop slightly but fans are always near maximum. Experienced this behaviour with a 6 year old Toshiba and a 4 year old Lenovo.
If this is a bad thermal paste, can one suggest a significantly better one at a not significantly price difference.
https://linustechtips.com/topic/1035916-cooler-master-master-gel/
The cooler master I think is pretty reputable quality thermal paste. There are probably better brands tho.
Also how are you using thermal paste on a laptop? Isn't it all glued together? I'd assume if you tore it apart and put it back together you might have a performance decrease.
linus sex tips
With the Toshiba, I had to perform a complete disassembly of the machine for a repaste while the Lenovo was a simple remove bottom lid and heatsink/fan affair.
