Hi all :) so first things first I’m watching a lot of LTT videos and Linus is always saying how good is the forum at LTT so I decided to try my luck here :)
And I know my English isn’t that good but hopefully you’ll understand my situation :)
So I bought an AC infinity T7 and S7 Fan System for my cabinet, then I had to exchange like 4-5 of them because of the fans, they’re just awful, so at the moment i still have the temp controller, all the plastics and metal grill, so the only thing that I need is the fans, together four of them, 2 in 2 out :)
What I need from the fans,
Preferably RGB or Black
Definitely quiet, like no hissing sounds and so on, I’m ok with air being moved sound :), and definitely possible to move a lots of air :) and of course they should work with the AC Infinity controller and use the existing holes from AC Infinity’s grills, since I have all the holes already sawed :D the price and so on doesn’t matter as long as it isn’t stupidly expensive :) and if that changed something I’m living in Germany so maybe here is a bit different availability :)
Hopefully I’ll be able to find the fix for my problem here, it’s already been soo long and nothing still works :D
https://linustechtips.com/topic/1035114-fan-suggestions/
The be quiet! pure wings 2 is usually a strong recommend, decently cheap and still good because it's a be quiet! fan.
https://pcpartpicker.com/product/M6vZxr/be-quiet-pure-wings-2-120-870-cfm-120mm-fan-bl039
And there's also the silent wings for static pressure:
https://pcpartpicker.com/product/kwgPxr/be-quiet-bl064-505-cfm-120mm-fan-bl064
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1035114-fan-suggestions/#findComment-12312212
Take a look at Noctua chromax line of fans. they have both Static pressure and airflow optimised ones to choose from in different sizes.
CPU: Intel i7 3930k w/OC & EK Supremacy EVO Block | Motherboard: Asus P9x79 Pro  | RAM: G.Skill 4x4 1866 CL9 | PSU: Seasonic Platinum 1000w Corsair RM 750w Gold (2021)|
VDU: Panasonic 42" Plasma | GPU: Gigabyte 1080ti Gaming OC & Barrow Block (RIP)...GTX 980ti | Sound: Asus Xonar D2X - Z5500 -FiiO X3K DAP/DAC - ATH-M50S | Case: Phantek Enthoo Primo White |
Storage: Samsung 850 Pro 1TB SSD + WD Blue 1TB SSD | Cooling: XSPC D5 Photon 270 Res & Pump | 2x XSPC AX240 White Rads | NexXxos Monsta 80x240 Rad P/P | NF-A12x25 fans |
https://linustechtips.com/topic/1035114-fan-suggestions/#findComment-12312344
How is the airflow in the cabinet set up? Is there ample ventilation for intake / exhaust or are the fans going to be drawing or pushing air through small slits / openings? Budget?
https://linustechtips.com/topic/1035114-fan-suggestions/#findComment-12314204
