Replacing Hard Drive
Go to solution Solved by Cyracus,
You can clone it then remove the original drive and set the clone to use the same letter directory that the old drive used through disk management (right click, change drive letter and paths...)
Hey guys, I don't know a lot about storage but I was wondering if I could replace my Hard Drive by cloning it even though it is in this configuration. Certain things are directed to my HDD and other things like the OS are held on my SSD. Im afraid if I clone the HDD it won't interact with the SSD correctly. Is this a non issue?
| Case: NZXT Tempest 210 | CPU: Intel Core i5 3570K @ 3.9 Ghz | GPU: ASUS ROG STRIX GTX 1070 | RAM: Crucial Ballistix Tactical 8GB |
| Mouse: Zowie FK1 | Monitor: Acer 21.5' | Keyboard: CoolerMaster Stealth w/ Brown Switches |
#KilledMyWife - #LinusButtPlug - #1080penis
https://linustechtips.com/topic/1034807-replacing-hard-drive/
desktop
r5 3600,3450@0.9v (0.875v get) 4.2ghz@1.25v (1.212 get) | custom loop cpu&gpu 1260mm nexxos xt45 | MSI b450i gaming ac | crucial ballistix 2x8 3000c15->3733c15@1.39v(1.376v get) |Zotac 2060 amp | 256GB Samsung 950 pro nvme | 1TB Adata su800 | 4TB HGST drive | Silverstone SX500-LG
HTPC
HTPC i3 7300 | Gigabyte GA-B250M-DS3H | 16GB G Skill | Adata XPG SX8000 128GB M.2 | Many HDDs | Rosewill FBM-01 | Corsair CXM 450W
https://linustechtips.com/topic/1034807-replacing-hard-drive/#findComment-12309656
