GTX 570 safe temps
Go to solution Solved by nsyedhasan,
I'd say keep it under 85C but you can go till 90C.
GPU's are safe until 90C and some even 100C. Your temps are fine.
In the case of Fermi 105C
Hi,
I was wondering what are safe temps for a gtx 570. I have the MSI Twin Frozer one, and I was thinking of setting the fan speed to a constant 40%, or maybe 45%, so it will be very quiet always. I've noticed that the gpu can get quite loud while gaming now that I've silenced other parts of my system.
So I go and set the fan speed, and then run Furmark. The GPU temp just keeps climbing and climbing. It reaches 75c and I just stop the test, because I don't want anything to get fried.
I know this is probably posted already, but the search function literally does not work. It just goes to some cloudflare page saying "Page not found" and lists other topics that are completely irrelevant with the current search.
https://linustechtips.com/topic/103459-gtx-570-safe-temps/
My Build Log on PCPartPicker FX-6300, ASUS M5A78L-M/USB3, MSI 7870 GHz Edition, Corsair Vengeance LP 1x8GB, 1TB WD Blue, Fractal Core 1000 USB 3.0, Corsair CX600, and my most recent addition that I've had forever and isnt new is a 80GB WD800 for Linux, Lenovo ThinkPad X131e, ASUS Transformer TF300T, Galaxy Note 3 Sister dropped it in a puddle I now have to use a Samsung Brightside, Beyerdynamic DT990 Pro 250ohm version, Blue Yeti  #TheRealKEH-JEFF | "Sometimes, if were lucky, in Australia, a family has 2 kangaroos to pick up the kids with" - marto | Your entry here | Remember kids; just because Linus has a video on it, doesn't mean that its the best choice | ts3.wferr.com the best TeamSpeak Abide by the CoC | Looking for build help? Read this before posting |
https://linustechtips.com/topic/103459-gtx-570-safe-temps/#findComment-1384050
Fermi is just fine running hot. You can let it run up to 90C for 24/7 operation.
[AMD Athlon 64 Mobile 4000+ Socket 754 | Gigabyte GA-K8NS Pro nForce3 | OCZ 2GB DDR PC3200 | Sapphire HD 3850 512MB AGP | 850 Evo | Seasonic 430W | Win XP/10]
https://linustechtips.com/topic/103459-gtx-570-safe-temps/#findComment-1384077
Fermi is just a space heater.
Listen if you care.
https://linustechtips.com/topic/103459-gtx-570-safe-temps/#findComment-1384097
I wouldn't really worry too much about furmark temps.
As long as it doesn't stay at over 95C constantly while gaming you should be fine.
I would say it has issues similar to that of the R9 290(X),that the chip itself runs relatively hot,and that the crappy stock heatsink doesn't help.
My GTX 480 never goes above 73C at a 20-22C ambient with the Accelero Twin Turbo heatsink on it.
Linus Sebastian said:
The stand is indeed made of metal but I wouldn't drive my car over a bridge made of it.
https://youtu.be/X5YXWqhL9ik?t=552
https://linustechtips.com/topic/103459-gtx-570-safe-temps/#findComment-1384108
