OK, I've Picked Parts For My First Build And I Was Wondering If The Parts I Picked Are Any Good. I've Already Got All The peripherals i need But Im Not 100% Sure On The Actual Specs.
My Budget is Around £550 (Flexible), Its Four Some Medium to high Gaming and Was wondering if You Could Help.
Thank You
https://linustechtips.com/topic/1033636-firts-build-please-help/
you wanna go with 3000MHz RAM or faster for Ryzen if you can also, I would go for the 2600X it's not that much more. and if you can spring another £30 jump to a ssd 5400rpm laptop drives are super slow especially as a boot drive. those would be my few recomendations
I lurk a lot
I'd recommend getting the r5 2600, the wraith cooler can handle the CPU even with a little overclocking, and get 3000 MHz ram, and you might want to upgrade the mobo to the msi mortar. Then there's the PSU, a quick search through the forums recommends not using that, maybe a be quiet system power 9 https://uk.pcpartpicker.com/product/b37v6h/be-quiet-system-power-9-500-w-80-bronze-certified-atx-power-supply-bn246  or for a bit more you can get a very nice be quiet pure power 10 https://uk.pcpartpicker.com/product/4kKhP6/be-quiet-pure-power-10-500w-80-silver-certified-atx-power-supply-bn273 since you rely on the PSU to keep your system running (and not kill your components with sloppy power) it's worth getting something with a good rep.
In order of importance, PSU, ram, CPU, mobo. You could also go for a 7200 rpm hard drive and save like £0.5 https://uk.pcpartpicker.com/product/HGTmP6/western-digital-internal-hard-drive-wd5000aakx
desktop
r5 3600,3450@0.9v (0.875v get) 4.2ghz@1.25v (1.212 get) | custom loop cpu&gpu 1260mm nexxos xt45 | MSI b450i gaming ac | crucial ballistix 2x8 3000c15->3733c15@1.39v(1.376v get) |Zotac 2060 amp | 256GB Samsung 950 pro nvme | 1TB Adata su800 | 4TB HGST drive | Silverstone SX500-LG
HTPC
HTPC i3 7300 | Gigabyte GA-B250M-DS3H | 16GB G Skill | Adata XPG SX8000 128GB M.2 | Many HDDs | Rosewill FBM-01 | Corsair CXM 450W
Spend a bit more and do something like this.
Bigger SSD as 120GB will fill up fast. Better board, psu and a 1TB HDD.
CPU: AMD - Ryzen 5 2600 3.4 GHz 6-Core Processor  (£144.95 @ AWD-IT)
Motherboard: MSI - B450M MORTAR Micro ATX AM4 Motherboard  (£88.97 @ Ebuyer)
Memory: Patriot - Viper 4 8 GB (2 x 4 GB) DDR4-3000 Memory  (£55.84 @ More Computers)
Storage: Crucial - MX500 250 GB 2.5" Solid State Drive  (£42.50 @ Aria PC)
Storage: Seagate - BarraCuda 1 TB 3.5" 7200RPM Internal Hard Drive  (£35.42 @ Amazon UK)
Video Card: Gigabyte - Radeon RX 570 4 GB Gaming 4G  Video Card  (£137.94 @ AWD-IT)
Case: Cooler Master - MasterBox Q300L MicroATX Mini Tower Case  (£45.46 @ Amazon UK)
Power Supply: Corsair - CXM (2015) 450 W 80+ Bronze Certified Semi-Modular ATX Power Supply  (£46.99 @ AWD-IT)
Total: £598.07
Generated by PCPartPicker 2019-02-14 21:15 GMT+0000
