55 minutes ago, cattaru said:
I'm looking at cases and I need it to fit matx idc about sfx psus but it has to support a 1070 ti mini from zotac and a micro atx board iv been looking for the smallest I can so far iv come down to the q300l from cooler master and the inwin 301
The Cooler master q300l is an excellent budget matx case, Corsair has a case called the crystal 280x which is actually very small (shorter but slightly wider than q300l, and they have an air 240 which doesn't have tempered glass but is slightly cheaper, Thermaltakes Level 20vt is cheaper than the 280x by a couple dollars but is slightly larger, another decent small matx case is the bitfenix prodigy. Slightly larger but still excellent cases include phanteks evolv matx, fractal meshify c mini, fractal focus mini, and corsairs 88r.
https://linustechtips.com/topic/1032746-m-atx-case-help/#findComment-12291540
You have google right?
Just search for "Carbide 88r size" and "nzxt s340 size"
NZXT S340 (CA-S340W-W1)
Motherboard Size ATX, Micro-ATX, Mini-ITX
Dimensions 445 mm × 200 mm × 432 mm 17.52 in × 7.87 in × 17.01 in
Prominent Features · 90% Steel Construction · Simple Interior Layout · Compact Size · Kraken™ Ready · ODD Free Design
Price $81 incl. shipping
Brand name
Corsair
Product Dimensions 44 x 19.8 x 37.8 cm
Item model number CC-9011086-WW
Color Black
Form Factor Micro-ATX, Mini-ITX
https://linustechtips.com/topic/1032746-m-atx-case-help/#findComment-12292061
