https://pcpartpicker.com/user/alphashen/saved/8yc9Jx
I just put some parts together and thought it was okay, I'm not planning to do anything out of the ordinary with this PC other than gaming and programming. Do you think everything is compatible? Will everything fit in the case and is the case fine. I would also like to find a cheap or free version of windows 10 if any of you could help :)
https://linustechtips.com/topic/1032691-pc-build-tips-advice/
