I have a VR setup in my living room and a work setup in my work room (cca. 20 meters apart).
Right now, I always unplug my PC and carry it over, when I want to switch in between playing VR games and working & playing non-VR games.
Is there any solution (like a port extender / dock), that would allow me to connect the work room with the living room?
For latency reasons I already have a network cable going from the living room (this is where the internet connection for the flat terminates) to my work room so adding an extra cable is not really an issue.
Since the main usage is VR, latency is a concern.
https://linustechtips.com/topic/1032156-remote-ports-through-optical-cable/
Your best option is probably an optical thunderbolt cable and dock, although those tend to be incredibly expensive, on the order of about $500 for a 30m cable. Then leave the PC in the living room and connect things in the office to the dock, since that is less latency restricted. You could also try an active USB cable to a powered dock and an active display cable.
It also might be worth trying out a lower spec machine (laptop?) with remote desktop as your work environment.
¯\_(ツ)_/¯
Desktop:
Intel Core i7-11700K | Noctua NH-D15S chromax.black | ASUS ROG Strix Z590-E Gaming WiFi  | 32 GB G.SKILL TridentZ 3200 MHz | ASUS TUF Gaming RTX 3080 | 1TB Samsung 980 Pro M.2 PCIe 4.0 SSD | 2TB WD Blue M.2 SATA SSD | Seasonic Focus GX-850 Fractal Design Meshify C Windows 10 Pro
Laptop:
HP Omen 15 | AMD Ryzen 7 5800H | 16 GB 3200 MHz | Nvidia RTX 3060 | 1 TB WD Black PCIe 3.0 SSD | 512 GB Micron PCIe 3.0 SSD | Windows 11
  • 2 weeks later...
