Is this a good choice for a power supply? - https://www.bestbuy.com/site/evga-80-plus-600w-atx-12v-eps-12v-power-supply-black/8511029.p?skuId=8511029
I'm going to be using it with the build in my signature until my other power supply that I had to RMA comes back. Thanks!
CPU: i7 8700 GPU: Asus ROG Strix GTX 1080 Mobo: Gigabyte Z370 Gaming 5 Ram: 16GB EVGA SuperSC SSD: Samsung 850 EVO 250GB
HDD: Seagate Barracuda 2TB PSU: TX650M Case: NZXT S340 Elite OS: Windows 10 Mouse: Logitech G403 Mouse Mat: HyperX Fury S Pro XL
Keyboard: CM Masterkeys Pro S (reds) Headphones: Sennheiser HD598 Monitor: Asus 24' MG248QR Devices: IPhone 11 Pro Max + 13' Macbook Pro
https://linustechtips.com/topic/1031347-power-supply-question/
1 minute ago, seon123 said:
No. That's a bottom of the barrel PSU. The CX450/M is usually the cheapest price that isn't crap.
Ok thank you, you think that 450w would be enough to power my build though?
https://linustechtips.com/topic/1031347-power-supply-question/#findComment-12279705
Yes, a 450W PSU should be enough to power a ~250-300W PC.
Edited by seon123
Something something
https://linustechtips.com/topic/1031347-power-supply-question/#findComment-12279749
Huh ok I thought my GPU would draw that alone but what do I know. Thanks for your help
https://linustechtips.com/topic/1031347-power-supply-question/#findComment-12279786
Its not about Watt its about the Quality of the PSU and how it works.
For example: Does it do 5V and 12V together or independantly?
"Hell is full of good meanings, but Heaven is full of good works"
https://linustechtips.com/topic/1031347-power-supply-question/#findComment-12279838
