So, I would like to not have to get a new case,sata cables, and a pcie wireless adapter which is an alternative to my problem. So here's the problem. My GPU runs HOT. Like we're talking 86 C at times because i popped it into a old prebuilt that mounts the PSU and GPU right next to each other. So i'm wondering if I could find a solution to this without having to spend $60 which is what it would take for the other solution.Is there anything I can do like an external GPU of some kind with PCIe extension cables or something?
https://linustechtips.com/topic/1029348-solution-to-this-issue/
1 minute ago, TheUncannyScrub said:
Depends really, you could go LTT style and get some zip ties, fans and tin snips.
Could something like this work at all? https://www.newegg.com/Product/Product.aspx?Item=N82E16812423198&Description=pci-e riser cable&cm_re=pci-e_riser_cable-_-12-423-198-_-Product
https://linustechtips.com/topic/1029348-solution-to-this-issue/#findComment-12261566
1 minute ago, YuppityYap said:
Although this would work, it would be terrible for gaming since it coverts to 1X, these are designed for Mining GPU's, not Gaming
https://linustechtips.com/topic/1029348-solution-to-this-issue/#findComment-12261573
Oh I see, I've seen a few empty external GPU enclosures on ebay. Could I perhaps buy one of those and pop my current GPU in it or is that not how they work?
https://linustechtips.com/topic/1029348-solution-to-this-issue/#findComment-12261580
Just now, TheUncannyScrub said:
Could you provide an example?
So, there are external GPUs such as this one. https://www.newegg.com/Product/Product.aspx?Item=9SIA8X58NK4046&Description=external gpu enclosure&cm_re=external_gpu_enclosure-_-9SIA8X58NK4046-_-Product. I've seen enclosures of them online(cant find them right now) but if  I found one of an empty version could that work?
https://linustechtips.com/topic/1029348-solution-to-this-issue/#findComment-12261593
Unfortunately, I dont think you have the port that is required for this on your motherboard
https://linustechtips.com/topic/1029348-solution-to-this-issue/#findComment-12261596
