Hi. I have an issue with JVC smart tv. I'm based in the UK and recently moved house the new talk talk router works fine but I have problem with the TV which for some reason requires me to set up the WiFi password each time I put the TV in standby. Once connected it works fine until powered down then the next time I switch on I have to set up the password again. I read something about duel channel hubs or assigning channels to the TV , dns, ip address etc. Does anyone know what this issue is and can you explain it as simple as possible so I can try and fix it, coz it's driving me nuts, cheers
https://linustechtips.com/topic/1027052-smart-tv-not-so-smart/
Not versed in this but Ive read a few things, one of those is to input manually the SSID of the router delivering the wireless signal within the TV options (the SSID is the name of your Network...like FBI Surveillance Van etc)
And make sure your network is not set to HIDE the SSID of your network (per JVC website)
Workstation Laptop: Dell Precision 7540, Xeon E-2276M, 32gb DDR4, Quadro T2000 GPU, 4k display
Wifes Rig: ASRock B550m Riptide, Ryzen 5 5600X, Sapphire Nitro+ RX 6700 XT, 16gb (2x8) 3600mhz V-Color Skywalker RAM, ARESGAME AGS 850w PSU, 1tb WD Black SN750, 500gb Crucial m.2, DIYPC MA01-G case
My Rig: ASRock B450m Pro4, Ryzen 5 3600, ARESGAME River 5 CPU cooler, EVGA RTX 2060 KO, 16gb (2x8) 3600mhz TeamGroup T-Force RAM, ARESGAME AGV750w PSU, 1tb WD Black SN750 NVMe Win 10 boot drive, 3tb Hitachi 7200 RPM HDD, Fractal Design Focus G Mini custom painted.
NVIDIA GeForce RTX 2060 video card benchmark result - AMD Ryzen 5 3600,ASRock B450M Pro4 (3dmark.com)
Daughter 1 Rig: ASrock B450 Pro4, Ryzen 7 1700 @ 4.2ghz all core 1.4vCore, AMD R9 Fury X w/ Swiftech KOMODO waterblock, Custom Loop 2x240mm + 1x120mm radiators in push/pull 16gb (2x8) Patriot Viper CL14 2666mhz RAM, Corsair HX850 PSU, 250gb Samsun 960 EVO NVMe Win 10 boot drive, 500gb Samsung 840 EVO SSD, 512GB TeamGroup MP30 M.2 SATA III SSD, SuperTalent 512gb SATA III SSD, CoolerMaster HAF XM Case.
https://www.3dmark.com/3dm/37004594?
Daughter 2 Rig: ASUS B350-PRIME ATX, Ryzen 7 1700, Sapphire Nitro+ R9 Fury Tri-X, 16gb (2x8) 3200mhz V-Color Skywalker, ANTEC Earthwatts 750w PSU, MasterLiquid Lite 120 AIO cooler in Push/Pull config as rear exhaust, 250gb Samsung 850 Evo SSD, Patriot Burst 240gb SSD, Cougar MX330-X Case
https://linustechtips.com/topic/1027052-smart-tv-not-so-smart/#findComment-12242632
@watzits
Heres the link, heres a screenshot of the JVC fix someone found with your same issue:
https://community.bt.com/t5/Home-setup-Wi-Fi-network/JVC-Smart-TV-Connection-Issues/m-p/1637195#M124238
https://linustechtips.com/topic/1027052-smart-tv-not-so-smart/#findComment-12242650
