Best Custom Case Builders
Go to solution Solved by LukeSavenije,
22 minutes ago, ChaseB said:
Yea. I want like a triangle or octagon shape. Bigger than the Mac Pro but only 1 fan solution if possible. Or I would do a signal 140 (/with Rad) in the bottom and a 200 up top. I am talking with protocase but wanted to see if anyone else had other companies they liked.
well... i like off the shelf personally. just look around a bit, pcpartpicker is a good source to look at, even if it's just to improve your concept
Hey guys. I am planning on doing a new build for my grandpa. Every build starts with a case and I want to make it special. I want to spend $200 to have someone build a truly custom case. I know about Protocase and I am trying to talk to them right now.Is there anyone else that yall would recommend. I am looking at ITX or MATX
Thanks
Chase B
Chase B
Sound Tech and GPU Expert
Are You New? Please Click on these links to help you out. Code Of Conduct | LTT Beginners Guide
https://linustechtips.com/topic/1026849-best-custom-case-builders/
2 minutes ago, LukeSavenije said:
modding the case?
I actually have a mb5 lite rgb modded with a mb500 front panel (it fits natively)
but that way you would make something truely one of a kind for a fair price
Are there any companies that can do it. I love modding but I want this to be perfect. Plus I want to do something special. Like build a circle or triangle case. Some weird but awesome shape.
Chase B
those are also available as a retail package. I personally don't know any companies that do it. I can see if I can find anything with your preferences, is that something?
Sure I was just asking for help. I really want to do something speacial for him. I want a case like no other. I want it to be quiet. I was planning to have only one fan for the whole case. I just want something custom and easy to build with. I plan on modding inside. I want to paint the inside red and the outside a Gloss Black
Chase B
21 minutes ago, LukeSavenije said:
The is a lot to mod. Hate it or love but I am thinking a design like Mac Pro. Intake in the bottom and one fan for exhaust in the top. No other ventilation needed.
Chase B
I don't know what you're putting in that, but that isn't going to be easy either (and hot if you don't do it correctly)
Chase B
