Ok so i just got a job and im making good money but i still dont want to soend too much since im just starting to get into the pc world but im planning on buying a hp compaq 6300 pro and add an intel core i5 3570 and an amd rx 460 but will this be even compatible and will the power supply be able to support this? Please and thank you for any help❤️
https://linustechtips.com/topic/1026295-need-help-will-it-work/
for the cpu i recomend upgrading later to something more powerful because a .2ghz change isnt that much for a new cpu. comparing a 3570 to a 3470<-(what comes with it). for the graphics card, it will fit in the motherboard and the power supply would probably come with a six prong connector for the graphics card. i am not concidering the software or any thing because i do not know anything in that field. overall get better cpu down the road and if the power supply doent come with it buy a new one with it if you have to. it will be cheaper to build and trust me, i was here, it seems very scary at first building it. i started out with a pre built i i kind of regret it. if you are sure you want to get in to pc gaming/ pcs do your resurch and watch a build video to know what you are doing. if you are not sure still do the reasurce to make sure you dont get ripped off or buying an out-dated system. the hp compaq 6300 seems to be a good starter pc. but it doesnt hurt to do your resurch
https://linustechtips.com/topic/1026295-need-help-will-it-work/#findComment-12238674
Whats your budget? I’m sure we could put a list together that will be better than that
✧・゚: *✧・゚:*  Quote for a reply  *:・゚✧*:・゚✧
✧・゚: *✧・゚:*   Ask for discord   *:・゚✧*:・゚✧
https://linustechtips.com/topic/1026295-need-help-will-it-work/#findComment-12238693
