Hey all,
So I have an Phanteks Enthoo Evolv X and my MOBO is a MSI Meg Z390 ACE. I believe I have it wired up correctly, and everything else works perfectly. However the power button on the case is not functioning, and I am having to turn it on manually using the button on the MOBO any time it turns off. For the moment I just have it set to never power off until I can fix it so I don't have to open the case every time I want to access it. Any suggestions on what could be wrong? Anyone else have this issue? Thanks for the feedback.
https://linustechtips.com/topic/1026002-power-button-not-working/
Double check your motherboard manual and double/triple verify you have the header plugged in properly. Chances are you dont. Its very rare that the button could be faulty too.
Community Standards
"Beast Mode"
Dedicated Streaming Rig
Alright, will open it back up today to confirm.
