I wanted some help with networking.
i plan to buy the NETGEAR xr700 which has a 10gb sfp+ and I wanted some suggestions on a pcie expansion card to put in my pc which would allow me to connect the 10 gb sfp+ port to have a direct connection to my pc.
yes I know it’s overkill but I plan on setting up a web server at some point.
https://linustechtips.com/topic/1023642-help-with-router/
https://www.newegg.com/Product/Product.aspx?Item=N82E16833114123&Description=PEX1000SFP2&cm_re=PEX1000SFP2-_-33-114-123-_-Product
Still completely unnecessary even for a webserver (unless you're planning for corporate website traffic levels) and that's ignoring the fact there is no way your external connection is 10gb. These things are designed for moving large files around internally at hyper fast speeds (for example Linus uses SFP to dump videos on to his ingest server) or data centres that do have 10gb of bandwidth to play with.
Main Rig:-
Server:-
https://linustechtips.com/topic/1023642-help-with-router/#findComment-12212252
