I have a 50 ft cable going from my router to my cable as the router is connected to another computer closer to it. Anyways, I got the cable and right away I was up and running with full speeds and low ping. But, I moved my computer it in again and now windows diagnostics is saying that it's broken or not plugged in correctly. Please help, any comment is appreciated.
https://linustechtips.com/topic/1023518-ethernet-cable-not-detected/
I would test with another computer if possible. I'd also consider that the cable might be kinked somewhere. 50 feet is pretty long, there could be damage somewhere. You can test that by moving the cable around and seeing if it works again.
Yes, it's 2871 as in the year 2871. I traveled all this way, back in time, just to help you. And you thought your mama lied when she said you were special-_-
