hi
looking to build my own computer for gaming
plz check if i got every part i need
motherboard: gigabyte b450 aorus m (100 euro)
processor: amd ryzen 5 2600 (175 euro)
graphic card: gigabyte geforce gtx 1050 ti (195 euro)
power source: corsair vs550 (60 euro)
ram: corsair vengeance lpx 16gb(2x8gb) ddr 4 dimm 3200mhz (160euro)
ssd: samsung 860 evo 500gb 2.5 inch (85 euro)
case: cooler master silencio 452 (90 euro)
total: 865 euro
should i switch some parts
tips are welcome
with love from belgium
https://linustechtips.com/topic/1023435-first-time-help/
Get a better psu and you could get a better gpu for the same price depending on how much rx 570s are in Belgium. Use the PSU tier list in the Cases and Power Supplies thread to find a good psu (tier 3 or above is recommended).
PC: CPU: i5-9600k - CPU Cooler: be quiet! Dark Rock Pro 4 - GPU: Sapphire Radeon RX 5700 XT 8GB GDDR6 - Motherboard: ASRock - Z370 Extreme4 - RAM: Team - T-Force Delta RGB 16 GB DDR4-3000 - PSU: Corsair - TXM Gold 550 W 80+ Gold Certified Semi-Modular ATX Power Supply - Case: Thermaltake - Core G21 TG
https://linustechtips.com/topic/1023435-first-time-help/#findComment-12210490
