Hi Guys,
So I recently upgraded my ram from a Corsair DDR4 2400 LPX 8gb kit (2x 4gb) to a G.Skill 3200 DD4 16gb kit (2x 8gb). I've been trying to set my memory speed to 3200 or at least 3000 but my games keep crashing. The most stable that I've been able to use is at 2866 and I'm stuck here. I've been reading through some other forums and checking other youtube videos to see how this can be done with no luck.
Here are the specs of my PC:
Processor: AMD Ryzen 5 1600 @ base clock (3.2ghz)
Memory: G.Skill 3200 16gb (2x 8GB Dual Channel)
Motherboard: Asus Prime B350 Plus (upgraded to the latest bios)
On the AI Tweaker, I've set the AI Overclock Tuner to D.O.C.P (D.O.C.P DDR4 3200 16-18-18-38) and the voltage to 1.35 v.
So far I'm stuck, anyone have any suggestions?
Thanks in advance!
The deep blue sky is infinitely high and crystal clear.
私はオタクではありません。
https://linustechtips.com/topic/1023266-ddr4-memory-speed-help/
likely need to up your SA voltage. Dont ever exceed 1.2v on that though. Likely set to auto. Try setting it to like 1.1 and testing.
Community Standards
"Beast Mode"
Dedicated Streaming Rig
https://linustechtips.com/topic/1023266-ddr4-memory-speed-help/#findComment-12209267
doesn't the new Ram have XMP?
CPU:i7 9700k 5047.5Mhz All Cores Mobo: MSI MPG Z390 Gaming Edge AC, RAM:Corsair Vengeance LPX 16GB 3200MHz DDR4 OC 3467Mhz GPU:MSI RTX 2070 ARMOR 8GB OC Storage:Samsung SSD 970 EVO NVMe M.2 250GB, 2x SSD ADATA PRO SP900 256GB, HDD WD CB 2TB, HDD GREEN 2TB PSU: Seasonic focus plus 750w Gold Display(s): 1st: LG 27UK650-W, 4K, IPS, HDR10, 10bit(8bit + A-FRC). 2nd: Samsung 24" LED Monitor (SE390), Cooling:Fazn CPU Cooler Aero 120T Push/pull Corsair ML PRO Fans Keyboard: Corsair K95 Platinum RGB mx Rapidfire Mouse:Razer Naga Chroma  Headset: Razer Kraken 7.1 Chroma Sound: Logitech X-540 5.1 Surround Sound Speaker Case: Modded Case Inverted, 5 intake 120mm, one exhaust 120mm.
https://linustechtips.com/topic/1023266-ddr4-memory-speed-help/#findComment-12209271
It does. I'm not sure how to set XMP on my board though. Forgive me, I'm a bit new to all this.
私はオタクではありません。
https://linustechtips.com/topic/1023266-ddr4-memory-speed-help/#findComment-12209272
D.O.C.P. is AMD's equivalent to XMP.
Community Standards
"Beast Mode"
https://linustechtips.com/topic/1023266-ddr4-memory-speed-help/#findComment-12209277
Ah okay. Thanks for clearing that up.
However, I have already tried DOCP and selecting the D.O.C.P DDR4 3200 16-18-18-38 setting. When it's set to 3200, Windows crashes at startup. I can get it to 3000 but it will crash in most of my games (Overwatch, Witcher 3 Monster Hunter World). The most stable I got it to work was on 2866.
私はオタクではありません。
https://linustechtips.com/topic/1023266-ddr4-memory-speed-help/#findComment-12209292
Do what I suggested and try upping your SA voltages to 1.1v and see what it does? Just make sure you do NOT go above 1.2v on there.
Community Standards
"Beast Mode"
https://linustechtips.com/topic/1023266-ddr4-memory-speed-help/#findComment-12209298
Not really sure how to do that, I don't see any SA settings on my board. Uploading some images just to be sure.
私はオタクではありません。
https://linustechtips.com/topic/1023266-ddr4-memory-speed-help/#findComment-12209318
Sorry, the VDDCR SOC voltage.
Community Standards
"Beast Mode"
https://linustechtips.com/topic/1023266-ddr4-memory-speed-help/#findComment-12209319
No go. I got a BSOD at startup. I tried changing the voltages by increments and still got BSOD. Ah well... thanks for the help anyway. I'll see if I can get some local technicians at the computer shop to help me with this.
私はオタクではありません。
https://linustechtips.com/topic/1023266-ddr4-memory-speed-help/#findComment-12209341
Try update the BIOS?
Desktop benching:
https://linustechtips.com/topic/1023266-ddr4-memory-speed-help/#findComment-12209505
Yeah, my first thoughts would be to update BIOS, set SOC to 1.1V and try bumping up DRAM voltage to 1.37V.  The other thing would be to make certain you installed the RAM into the slots the manual instructs to use.  The ASUS boards I've used use the 2nd and 4th slots counting from the CPU socket.
AMD Ryzen 5800XFractal Design S36 360 AIO w/6 Corsair SP120L fans  |  Asus Crosshair VII WiFi X470  |  G.SKILL TridentZ 4400CL19 2x8GB @ 3800MHz 14-14-14-14-30  |  EVGA 3080 FTW3 Hybrid  |  Samsung 970 EVO M.2 NVMe 500GB - Boot Drive  |  Samsung 850 EVO SSD 1TB - Game Drive  |  Seagate 1TB HDD - Media Drive  |  EVGA 650 G3 PSU | Thermaltake Core P3 Case
https://linustechtips.com/topic/1023266-ddr4-memory-speed-help/#findComment-12210214
That's the first thing I did after installing the new RAM.
I'll try fiddling with the SOC and the DRAM voltage. And yes, I'm certain I've installed the RAM on the slots the Manual has required.
Thanks for the help so far everyone.
私はオタクではありません。
https://linustechtips.com/topic/1023266-ddr4-memory-speed-help/#findComment-12210899
my asrock pro4 and pro4m would handle and RAMs above 2666 til update. now can OC 3800 on 3600 16-16-18-32.
asus has a lot better RAM profiling than asrock on UEFI, does your system boot loop a couple of times and fail? or just fail?
https://linustechtips.com/topic/1023266-ddr4-memory-speed-help/#findComment-12210912
then maybe just the CPU having problems with its memory controller. 1st gen Ryzen don't do well in this department.
Desktop benching:
https://linustechtips.com/topic/1023266-ddr4-memory-speed-help/#findComment-12210917
