16 minutes ago, Aljaz said:
So my pc was working fine with iGPU always boot up and now that i bought new GPU is not showing any life on monitor pc itself is running but monitor no picture....any help please....
Specs please!
CPU:i7 9700k 5047.5Mhz All Cores Mobo: MSI MPG Z390 Gaming Edge AC, RAM:Corsair Vengeance LPX 16GB 3200MHz DDR4 OC 3467Mhz GPU:MSI RTX 2070 ARMOR 8GB OC Storage:Samsung SSD 970 EVO NVMe M.2 250GB, 2x SSD ADATA PRO SP900 256GB, HDD WD CB 2TB, HDD GREEN 2TB PSU: Seasonic focus plus 750w Gold Display(s): 1st: LG 27UK650-W, 4K, IPS, HDR10, 10bit(8bit + A-FRC). 2nd: Samsung 24" LED Monitor (SE390), Cooling:Fazn CPU Cooler Aero 120T Push/pull Corsair ML PRO Fans Keyboard: Corsair K95 Platinum RGB mx Rapidfire Mouse:Razer Naga Chroma  Headset: Razer Kraken 7.1 Chroma Sound: Logitech X-540 5.1 Surround Sound Speaker Case: Modded Case Inverted, 5 intake 120mm, one exhaust 120mm.
https://linustechtips.com/topic/1023246-problem-with-boot/#findComment-12209120
Ryzen 2400g
8 gb ram (kingston fury 2666)
2 ssd
1 2Tb hdd
RX 570 4GB (pulse version)
PSU (cooler master masterwatt 450W)
@Constantin
450w is quite small, it may be from the PSU
https://linustechtips.com/topic/1023246-problem-with-boot/#findComment-12209142
1 minute ago, Aljaz said:
U think it’s psu? It’s weird cuz I have watt meter adapter and when I’m playing games like gta v it gets only on 190-210 Watts. @Constantin
With iGPU?
https://linustechtips.com/topic/1023246-problem-with-boot/#findComment-12209152
Well if you tried everything, then you should test the gpu on another computer.
Just go on a local shop, i think they will test it for you.
https://linustechtips.com/topic/1023246-problem-with-boot/#findComment-12209166
