Im having a problem, so my pc is one month old and I know it’s should be working properly...every time I turn it off and then turn it on can’t get monitor to display....this is my second time getting this. First time I resetted CMOS and it worked fine then but I want it to work with no hardware resetting...is possible that PSU is not working properly?
https://linustechtips.com/topic/1023233-pc-boots-no-display/
could be gpu not working properly. resit it and make sure the power cables on either end are firmly pushed in with no cracks in the rubber coating. also try a different display cable as it might be broken
CPU: i7 4790k
GPU: Gigabyte Windforce3 GTX 1080
RAM: 8GB Corsair Vengance 1600MHz (@1333Mhz) + 8GB Balisticx Sport or something 1333MHz
MOBO: MSI Z97 Gaming 5
PSU: 1000W EVGA 1000G 80+ GOLD
Case: Dark Base 700
Cooling: Dark Rock Pro 3 CPU Cooler + Standard Case Fans
Drives: Intel SSD5 180GB (Boot Drive) + Seagate Baracuda 1TB HDD + Seagate Baracuda 4TB HDD
Keyboard: Razer Blackwidow RGB 2013
Mouse: Corsair Harpoon RGB
Speakers: Creative T15 Bluetooth Speakers
Microphone: Samson Meteor Mic
Monitor: AOC G2590VXQ 75Hz + ASUS VS247 + Shitty Generic 1080p 60Hz TV
LED Controller: NZXT HUE+
https://linustechtips.com/topic/1023233-pc-boots-no-display/#findComment-12208988
Is the gpu pushed into the slot enough? have you installed the drivers? is your display cable connected to the gpu?
CPU: i7 4790k
Case: Dark Base 700
https://linustechtips.com/topic/1023233-pc-boots-no-display/#findComment-12210735
Yes 8 pin connector is connected (properly), gpu is fully inside pcie slot (x16)
and the drivers are installed. As I said gpu itself is running normally no loud fan spinning ,normal gpu but just not displaying...i can get it working by reseting the cmos but with the first shut down, reset, sleep.... no picture. @benji_
https://linustechtips.com/topic/1023233-pc-boots-no-display/#findComment-12211191
