Pc specs:
PNY GTX 1070 ti
Ryzen 7 1700x
insignia 550w  psu
Inland Professional 120gb sata ssd
Western Digital 500gb HDD
Cool Master Master Liquid ML 120 AIO
ASRock AB350m
G.Skill Aegis 2x8gb ddr4 3000mhz
I recently tried using XOC precision OC rather than my typical MSI Afterburner. Prior to attempting to use XOC I had an avg fps of 250 on high settings at 1080p on Fortnite, BO4, Fallout 76, BF5, and other games, but after I tried using the program I had an issue where my frames locked to 185 on a 75htz panel. To resolve the issue I uninstalled XOC and got the frames uncapped, but after returning to MSI AB my frames have been averaging about 125 and I have done a BIOS update, Driver reinstall, game reinstall, but I have had no luck I was wondering what I should do to resolve the problem?
Note!
I have made sure that my global 3d settings have Vsync turned off, and my prefered texture filtering is High Performance
I have also made sure that my power management options are set to Ultimate Performance (this setting is only available on high end pcs)
Edited by Zqcr
text color
https://linustechtips.com/topic/1022278-hardware-problems/
