That's called an IDE cable, or PATA.
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1020888-old-hdd-help/#findComment-12187193
Just now, fuzz0r said:
That is an IDE hard drive.
I don't know if IDE to SATA exists? But probably.
They do but they require some cable jankery. An IDE to USB would be a lot more convenient.
Primary PC:
PSU tier list
https://linustechtips.com/topic/1020888-old-hdd-help/#findComment-12187194
https://linustechtips.com/topic/1020888-old-hdd-help/#findComment-12187281
Well what if it is USB like this one? https://www.amazon.com/AGPtek-Drive-Adapter-Converter-External/dp/B00BIE996S/ref=mp_s_a_1_2?ie=UTF8&qid=1547401474&sr=8-2-spons&pi=AC_SX236_SY340_QL65&keywords=IDE+to+usb&psc=1
https://linustechtips.com/topic/1020888-old-hdd-help/#findComment-12187285
3 minutes ago, Fosh612 said:
I believe that would work, it has independent power and data which are usually required for these hard drives.
Primary PC:
PSU tier list
https://linustechtips.com/topic/1020888-old-hdd-help/#findComment-12187299
2 minutes ago, Fosh612 said:
Okay thank you for the help!
It helps to read user reviews just in case
Primary PC:
PSU tier list
https://linustechtips.com/topic/1020888-old-hdd-help/#findComment-12187313
I use a usb hard drive adapter. Runs 12-15 bucks at microcenter. It has a desktop ide, laptop ide, and sata plug. It also comes with a wall wart and adapter to power drives.
They do make a reversible ide to sata adapter, and a laptop to desktop ide adapter. The ide to sata adapters are flaky at best and using a combination of two adapters is not advisable. Can it be done? Definitely, but it is expensive and silly.
https://linustechtips.com/topic/1020888-old-hdd-help/#findComment-12187388
https://linustechtips.com/topic/1020888-old-hdd-help/#findComment-12187399
