Hi!
My problem is that when i record or stream a game or something my headset audio becoms eccoy becuse of my headsets 7.1 virutal surond (g633). (I dont want to turn it of becuse, why then have a 7.1 headset)
I started to use voicemeeter bannana to fix it and it worked if i use voicemeeters virutal input as defult device in windows playback, but when i do so my audio in my headphones becomes very muddy becuse its going thrue viocemeeter and back in to my headphones.
And if i use my headset as standard divce i dont get any audio to voicemeeter.
Is there a way to get audio from my games directly to my headphones and to voicemeeter at the same time and then be abel to use the voice meeter audio in obs.
( if i where able to make my heaset to a hardwaer input it would probebly solve it, but how do i get it as a hardwaer input? )
https://linustechtips.com/topic/1020818-audio-problems/
Hello everyone,
Many people is facing the audio problem and now it is a common problem. I also faced this problem, after a lots of research I found the answer.
If you really want to get rid of this problem follow this steps that given below:-
  • First you have to connect to the internet.
  • Hit the start button, and type the device manager into the start search field.
  • Now hit the 2 time sound, video and game controllers button.
  • After of this step hit the right click the name of the device listed under sound, video and game controllers.
  • Now the final step select update driver software.
I hope it will helps you.
Thank You.
https://linustechtips.com/topic/1020818-audio-problems/#findComment-12189240
Someone else had a similar situation today. Try going into your source in your scene in OBS and either turn the mixer audio for that device to Monitor (mute output) or Monitor off. If you're actually getting sound from Banana in your headphone then this should stop the other source coming to your headphones. As usual you wanna record and see if that stops it before you stream again. I hope this helps.
https://linustechtips.com/topic/1020818-audio-problems/#findComment-12218353
