i think i have something wrong with my motherboard. i overclocked my pc when my motherboard wasnt capable of overclocking. and now my pc is slower than it was before. i have checked everything without my motherboard because i dont now how to check it. how do i find out if my motherboard is broken or not
https://linustechtips.com/topic/1019725-i-need-help/
The whole idea is a mess.
Just to discard any missconfiguration, reset your motherboard to default settings and try again.
If there is any recorrent problem, state the context of the issue. Software used, hardware configuration and performance obtained. There are many possible issues and many possible solutions.
cheers.
https://linustechtips.com/topic/1019725-i-need-help/#findComment-12176941
