Cpu Choice Problem
Go to solution Solved by Jurrunio,
If you already have a graphics card and plan on continue using that, then that's not a good upgrade. 2200G is about 15-25% faster, which is small for your expense. If you don't have a graphics card though the 2200G is much better, because Vega 8 is magnitudes faster than whatever's in the 3450
Greetings folks! I currently have an Intel Core I5 3470 which has a bit of age now adays, so I've been having the idea on building a whole new Unit. I have my eyes on the Ryzen 3 2200g cause i think it's a very good value for the money. Which brings my question. Will it be reasonable to change into Ryzen 3 2200g vs. My already owned Intel core i5 3470? Thanks for your thoughts...
https://linustechtips.com/topic/1019530-cpu-choice-problem/
What do you use your computer for?
Main Rig CPU: AMD Ryzen 7 5700x GPU: Asus TUF Gaming RTX 3080 OC MBASUS AM4 TUF Gaming X570-Plus RAM: 64GB Corsair Dominator Platinum 3200 CPU Cooler: Cooler Master Master Liquid LC240E SSD: Crucial 250gb M.2 + Crucial 500gb SSD + 4TB Crucial SSD HDD:None PSU: Thermaltake Toughpower Gran RGB 850W 80+ Gold Case: Corsair Carbide 275R KB: Glorious GMMK 85% MOUSE: Razer Naga Trinity HEADSET: Go XLR with Shure SM7B mic and beyerdynamic DT 990
unRAID Plex Server CPU: Intel i7 6700 GPU: Nvidia Quadro P2000 MB: Asus B150M-C RAM: Crucial Ballistix 32gb DDR4 3000MT/s CPU Cooler: Stock Intel SSD: Western Digital 500GB Red HDD: 4TB Seagate Baracude 3x 4TB Seagate Ironwolf PSU: EVGA BT 80+ Bronze 450W Case: Cooler Master HAF XB EVO KB: Cheap Logitech KB + Mouse combo
https://linustechtips.com/topic/1019530-cpu-choice-problem/#findComment-12174898
Desktop benching:
https://linustechtips.com/topic/1019530-cpu-choice-problem/#findComment-12174966
Just now, RazSiLog said:
Mainly gaming, but sometimes photoshop, 3d modeling and animation....
I'd step up to at minimum the Ryzen 5 2600 then. (I'll also presume you have a GPU as well since it will be needed with that CPU)
The 2600 is only around $150
https://linustechtips.com/topic/1019530-cpu-choice-problem/#findComment-12175031
I'm currently using a gtx 550 ti but i think vega 8 will burry that gpu. What do you think?
https://linustechtips.com/topic/1019530-cpu-choice-problem/#findComment-12175033
Yeah you're right about that. The Vega 8 will out perform a 550 ti. Of course you always upgrade both ;) For around $370 I was able to get a 2600 and a RX580
https://linustechtips.com/topic/1019530-cpu-choice-problem/#findComment-12175040
Ohh awesome. I think i will be needing to up my budget a little more than. Thank you very much for your time.
https://linustechtips.com/topic/1019530-cpu-choice-problem/#findComment-12175059
I would see what comes out in the summer or fall from AMD and intel unless you need a new system now.  If you are going to buy an APU I think the R5 2400G is a slightly better investment over the 2200G, however, just like another poster said the 2600 and 580 are both at amazing prices right now and those two upgrades will be significant and provide an amazing experience over your old computer.
https://linustechtips.com/topic/1019530-cpu-choice-problem/#findComment-12175544
