hi im locking for help with water cooling for my pc im new to water cooling
i need a block for my gpu i found this "EK-FC1080 GTX Ti TF6 - Acetal+Nickel"
im locking on this case "Thermaltake Core X71 TG Edition"
i have a msi x399 sli motherboard
my gpu is a msi geforce gtx 1080 ti gaming x trio the block i have found should work but rather safe then sorry
my cpu is a Threadripper 1950X
my psu is a EVGA SuperNOVA 750 G2 v2  - 750 Watt - 140 mm - 80 Plus Gold certified
the tower i have at the moment is a Cooler Master CM Storm Trooper
i want to do hard line
https://linustechtips.com/topic/1019016-locking-form-help-with-water-cooling/
ok?
Builds:
Well if ek lists that block being compatible with your card, then you are good there.
They also have a tool on their site to get you the correct cpu block and what raditor support your case will normally have.
What exactly are you trying to figure out?
