So my Realtek audio high definition manager is gone from my system it says it is installed but when I try to connect my headphones and speakers they aren't detected and the audio manager doesn't pop up on screen and I can't find the application anywhere on my system even though it says it is installed anyone know what the problem might be?
https://linustechtips.com/topic/1018632-realtek-audio/
2 minutes ago, Phaytuh said:
I've had an issue similar to this before on my PC where the automatic jack detection broke so it couldn't tell when I plugged something in. Google how to disable automatic jack detection and see of that fixes it. You should be able to do it by going the the red speaker icon in your task bar, right clicking it, and opening the audio manager thing.
I'm not able to access my Realtek audio manager thought in storage it says it is installed but when I go search for it in file explorer etc it is nowhere to be found
https://linustechtips.com/topic/1018632-realtek-audio/#findComment-12166298
Just now, Phaytuh said:
Hmm, have you tried going into device manager and seeing if it is listed there? If so, try disabling then re-enabling it and restarting.
not there either first place I checked the only devices detected are my 3 monitors even thought my headset and speakers are plugged in
https://linustechtips.com/topic/1018632-realtek-audio/#findComment-12166338
